Home > Technical > Metal gasket + RTV?
Welkman
Metal gasket + RTV?
Hi all,
The pipe from the oil filter to the sump on my TD5 is leaking badly at the sump end. I have drained the oil and removed the metal pipe. I really dont want to do this twice so should I used RTV and the metal gaskets or just go with the standard metal gaskets and torque to spec? I Think it has been overtightened but does not appear warped when checked with a straight edge.
Post #644161 15th Aug 2017 1:30pm
dorsetsmith
Embarassed
Post #644172 15th Aug 2017 3:02pm
Welkman
could you clarify what tube nut and olive means? On both of the TD5 engines I have there were gaskets on the upper and lower connections.
Post #644173 15th Aug 2017 3:04pm
dorsetsmith
my fault stop read post on my phone
standard metal gaskets at the top and bottom torque to spec
http://www.brit-car.co.uk/product.php/9959...iscovery_2
Post #644174 15th Aug 2017 3:07pm
Welkman
I just had a check of the diagram and it needs two of these - LRJ100000
I will try with just the fresh gaskets and clean mating surfaces torqued to spec (10nm). If that fails I will drain the oil again and try my luck with RTV.
Thanks
Post #644176 15th Aug 2017 3:15pm
dorsetsmith
This type metal gasket one shot only can not be reused
Post #644177 15th Aug 2017 3:17pm
Welkman
Yep - I think I disconnected the tube when doing the rear main oil seal as I had to drop the sump so hopefully a new gasket will sort it. It was leaking incredibly badly!
Post #644178 15th Aug 2017 3:22pm
Welkman
All done - gaskets six quid from the stealer. Torque is 10nm which does not seem all that much but no leaks so far. Cleaned up the mating surfaces on a flat steel table with some p1000 sandpaper first.
Post #644448 16th Aug 2017 2:23pm
