![]() | Home > Technical > Metal gasket + RTV? |
![]() Last edited by dorsetsmith on 15th Aug 2017 3:15pm. Edited 2 times in total |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 332 ![]() ![]() |
could you clarify what tube nut and olive means? On both of the TD5 engines I have there were gaskets on the upper and lower connections.
my fault stop read post on my phone
standard metal gaskets at the top and bottom torque to spec http://www.brit-car.co.uk/product.php/9959...iscovery_2 |
I just had a check of the diagram and it needs two of these - LRJ100000
I will try with just the fresh gaskets and clean mating surfaces torqued to spec (10nm). If that fails I will drain the oil again and try my luck with RTV. Thanks |
This type metal gasket one shot only can not be reused
Yep - I think I disconnected the tube when doing the rear main oil seal as I had to drop the sump so hopefully a new gasket will sort it. It was leaking incredibly badly!
All done - gaskets six quid from the stealer. Torque is 10nm which does not seem all that much but no leaks so far. Cleaned up the mating surfaces on a flat steel table with some p1000 sandpaper first.
