Home > 130 > Dealin with rust |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
If you're really going for clean then a proper bead blast/ acid dip will get rid of anything nasty, however it might uncover more than you expect!
Then dinitrol or similar to protect |
15th Aug 2017 8:00am |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
Wire brush, degrease, sand down, rust kill, primer, paint, waxoil/dinitrol/buzzweld 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
15th Aug 2017 8:44am |
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 |
Rust Kill?
I have found products called rust converter... Dinitrol will be hazardous to transport, I have to try and find a product locally that does the same thing. I may use bedliner, but the chaps here want the same amount as a new chassis shipped... |
15th Aug 2017 9:16am |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Surely if you've gone that far, it would be worth getting it blasted and galvanised??
Some would argue about galvanising an older chassis, but I had my 1956 86" done, and it came up a treat inside and out, Also, it would probably work out a cheaper option. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
15th Aug 2017 9:17am |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
Never done anything that major, but I wire brush, treat with Fertan, paint (sometimes, usually with POR-15) then Dinitrol.
Would also use the Bilt Hamber products (instead of dinitrol) Fertan seems really good for converting rust and helping prevent future rust.,.. I'm impressed how good it is! http://www.fertan.co.uk/ Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
15th Aug 2017 9:24am |
Yes rust converter is the same, raptor bed liner is very easy to use but it does go everywhere 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
15th Aug 2017 9:30am |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 616 |
Look for marine type paints and chemicals also. Your are in Kuwait so I think, someone there repair boats. and repairin boats = fighting with corrosion. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
15th Aug 2017 10:08am |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2158 |
Tbh Naf it seems youre in the middle east, not as though it's going to be that wet!!
Sand off any major rust with a grinder and wire wheel (buy loads) then paint. As MadTom said boat repair places should have what you need. Coat of red oxide then bedliner (Raptor/LineX etc) will keep it solid for a good while |
15th Aug 2017 10:24am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20314 |
I'd consider galvanising as you have got it to where it is. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
15th Aug 2017 11:19am |
Neilios Member Since: 01 Nov 2017 Location: Co. Durham Posts: 169 |
I have to agree, if it's down that far do it with a galvanised chassis, you will never be happy otherwise, you can get carried away though, I have 110 in hundreds of bits, every time some thing is removed, I blast and paint/galvanise the process is taking ages but the result willl be worth it, keep the pictures coming.
27th Nov 2017 6:09am |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 |
I agree with Ian if you have gone this far if you can get it galvanised I would. The chassis rot also from the inside out so I would go all over it with a small hammer, tapping the metal, if it rings its ok but if you hear a dull thud then it will probably need some welding first before galvanising. I also had my 1955 chassis galvanised some 26 years ago and its still in excellent condition.
27th Nov 2017 12:32pm |
MJN110 Member Since: 18 May 2015 Location: North Yorkshire Posts: 380 |
If I was at that stage it would definitely be a new galv chassis for me anything other than that is half a job
As has already been pointed out they rust from the inside out. |
27th Nov 2017 2:55pm |
Por15 using their metal prep Ray
27th Nov 2017 3:22pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
Does galvanising harden the steel ?
27th Nov 2017 7:47pm |
