Home > Maintenance & Modifications > Swapping transfer box gears without dropping box? |
you need to remove intermediate gear,to swoop it over and this can only be cared out with box removed from the land rover as intermediate gear has shaft that can only removed with the LT230 box removed from main gear box
video is for type T lt230 box Last edited by dorsetsmith on 14th Aug 2017 11:18am. Edited 2 times in total |
14th Aug 2017 10:17am |
drinkdrinkdrop Member Since: 13 Sep 2016 Location: Surrey Posts: 76 |
As I feared, thanks
14th Aug 2017 10:21am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17391 |
You shouldn't need to strip out the interior to remove the transfer box, everything can be done from underneath.
14th Aug 2017 10:38am |
I saw a few tutorials and they seemed to remove the transmission tunnel cover and the floor but on second viewing this appears to be for easier access to the transfer lever mechanism. If I can undo that from underneath that should solve my issue
14th Aug 2017 11:37am |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
First time I dropped an r380 I did remove the transmission tunnel, mostly because I used an engine crane.
Second time I slackened it off, to make access a easier, but removal wouldn't be imperative for getting the transfer box off. I'd recommend opening up the access panel under the centre seat/cubby box though, makes a big difference. Also worth remembering that the transfer box is heavy and ungainly! |
14th Aug 2017 2:56pm |
