Home > Puma (Tdci) > Gearbox (MT82) filler plug...
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Can anyone shed some light on the size of Torx bit I need to undo the filler plug and drain plug on the MT82 gearbox of my Puma tractor?
Just got it back from the service chappies, and want to change the loobygoo... It's still ever so slightly snatchy changing into 2nd... But a million times better than before it went in for a new clutch and associated bits n bobs!
Cheers,
Paul. ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #68876 27th Apr 2011 11:09pm
dgardel
Italy
Drain plug
Filler plug
DO NOT USE the filler plug for the oil level.....
You MUST fill in the right quantity (otherwise the pressure can give you oil leaks from the oil seals)
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #68899 28th Apr 2011 8:46am
Shax
Solved the mystery!!
Took a trip to Halfords to get the required Torx bit.. I managed to get the "assistants" to let me take the T50 and T55 bits out of the store to check the size before I paid.. Turns out that both the filler and drain plugs need a 12mm allen key and not Torx bits, so had to ask again if I could take more stock outside without paying!! I tried a 12mm 1/2 inch drive Allen key, fitted perfectly, now here's the rub, you cant get a bloody ratchet in the space to undo the filler plug. Buggritt!!! Big Cry
Then I saw a set of drain plug keys hanging on the stand, took them outside, and checked that they would fit.. The 12mm key fits perfectly, and along with a 19mm ratchet ring spanner, the plug is easily removed and replaced. Very Happy Cost £19.99 for the set, but will come in useful for other jobs.. Thumbs Up ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #68984 28th Apr 2011 10:01pm
MK
Not sure if it is a pressure matter but rather a lubrication design issue. The MT82 fitted on Mustangs uses 2.6l. Puma 110" SW
Post #69183 1st May 2011 10:25am
Milmur64
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Hello I have a 2015 Defender with the 6 speed gear box MT82. The vehicle has done circa 13k miles and I want to change the gear box oil. Found the outlet plug but struggling to establish which is the fill plug. I have researched via the internet/ Yuo Tube, etc and i am more confused than ever! Local dealership was no help which is sadly very disappointing and just gave me a set of isometric workshop manual drawings which was of little help due to poor quality of copy.
Can someone advise me please.
Attached photo of an 8mm hexagonal plug on driver side that I think might be the filler appeture, but I am unsure?
Any advice will be appreciated.
Regards,
Jonathan
Post #643254 11th Aug 2017 6:20pm
LR90XS2011
see dgardel post above with pictures DEFENDER 90 TDCI XS,
Post #643255 11th Aug 2017 6:39pm
dgardel
Italy
Regards,
Jonathan
yes it is! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #643263 11th Aug 2017 7:00pm
dorsetsmith
You MUST fill in the right quantity (otherwise the pressure can give you oil leaks from the oil seals) ?
has gear box not got breather pipe work Question
Post #643279 11th Aug 2017 7:55pm
MK
I think it does..
In my case I replaced both fill and drain plugs with std bronze ones. Puma 110" SW
Post #643341 11th Aug 2017 11:24pm
Milmur64
Many thanks everyone the advice and information has proved invaluable. Regards Jonathan
Post #643507 12th Aug 2017 6:59pm
zsd-puma
It does, it's probably more to do with certain seals in the box not being designed for constant submersion in oil. Some gearboxes also generate their own pressure internally rather than being simply splash fed.
Either way the MT82 in the Defender is designed and tested to take 2.2 litres for a service change it's not designed as a spill fill box, so putting any more in will simply be a waste of oil at the very least.
Post #643549 13th Aug 2017 1:53am
Milmur64
Many thanks for all the additional information regarding the MT82 box all very useful and confidence boosting.
Once again thanks to everyone who has taken the trouble to reply to my initial post - very much appreciated!
Regards
Jonathan
Post #643797 14th Aug 2017 8:18am
dgardel
Italy
MT82 Getrag Work Shop Manual
https://1drv.ms/b/s!AnHBx4Wc2MJLhD46SXKHxgIs4mgo Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #644950 18th Aug 2017 9:47pm
Phillywilly72
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Tamar Blue
Just replaced my gearbox oil with over 2.7L coming out of my 2011 puma. What should I look for to check damage?
Post #1033451 30th Apr 2024 8:42pm
Naks
^ metal filings in the oil? --
Post #1033474 1st May 2024 7:09am
