![]() | Home > Technical > 110 Turrets. |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1769 ![]() ![]() ![]() |
I believe you only need longer turrets on more extreme lifts. I'd also recommend fitting tubular ones or the gwyn lewis style, they're meant to rust less and are easier to fit!
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 ![]() ![]() |
+1 on Gwyn Lewis ones, galvanised and when fitted means you can change a shock without removing the spring which is a bonus!
