Home > Technical > 110 Turrets.
Griff
Wales
110 Turrets.
Doing a rolling restoration on a TD5 110 at the moment and front turrets are rusted through and need replacing. The turrets fitted at the moment look standard even though it has yellow front springs which im guessing are a 2" lift but not sure on spring lengths to check.If as I suspect it has a 2" lift should I fit longer turrets or just replace with standard ? Any advice appreciated.
Post #642794 9th Aug 2017 5:07pm
miker
I believe you only need longer turrets on more extreme lifts. I'd also recommend fitting tubular ones or the gwyn lewis style, they're meant to rust less and are easier to fit!
Post #642797 9th Aug 2017 5:20pm
bankz5152
+1 on Gwyn Lewis ones, galvanised and when fitted means you can change a shock without removing the spring which is a bonus!
Post #642831 9th Aug 2017 7:39pm
