Home > Maintenance & Modifications > Is it me? Or my Britpart Dual Battery Management System? |
Is your starter battery any good? I mean is it actually taking a full charge?
8th Aug 2017 11:56pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
Is the aux battery flat too or just starter battery?
Ie is it all connected up correctly? |
9th Aug 2017 7:04am |
acuss01 Member Since: 27 Jun 2014 Location: London Posts: 225 |
Yeah both batteries normally show voltage when you hit the 'display' button.
Good question Caterham about checking if the AUX battery is actually flat (ie if they are wired the right way round). Since this upgrade was supplied and fitted by a site sponsor I assume it would be, but need to rule that out I guess! For now I just want to be clear that its not a switch or button I am missing that sets the starter battery to be isolated. Its automatic I thought... You only press 'Link' button if you want to manually override the isolation and link them together for extra power (eg winch) 2015 110 XS CSW Montalcino Red with Black Pack |
9th Aug 2017 8:59am |
dantastic Member Since: 04 May 2010 Location: London Posts: 367 |
We've had a lot of trouble with the Odysseys on the challenge trucks in my club. They measure the correct voltage over the terminals but they are flat as pancakes.
Have someone measure the voltage (with a multimeter) as you try to crank. My guess is you'll see the voltage drop quite a lot, like 6-10v. Could be wiring as well obviously but the story certainly quacks like a familiar duck.... |
9th Aug 2017 10:26am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8021 |
Next time you leave it why not disconnect the starter of Battery. And see. What's the charges like in the aux. And starter battery 3 days later. Compare that with leaving it connected. Odysseys aren't quite what they used to be, likewise seen quite a few issues with them on challenge scene lately Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
9th Aug 2017 2:43pm |
