Home > Maintenance & Modifications > Is it me? Or my Britpart Dual Battery Management System?
acuss01
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
I've had to get my truck jump started three times in the last few weeks, even though I have a Britpart dual battery system.
Can anyone explain why?
The system was fitted a year ago on a recommendation. It manages two Odyssey PC1500 batteries. As I understand it, the batteries are linked whilst the vehicle is running (ie charged by the alternator).
But when the vehicle is stopped they are automatically unlinked. This isolates the starter battery so things like my fridge or inverter continue to run off the aux battery.
So even if I leave my fridge on for days, and runs down the aux battery, it shouldn't affect my starter battery right?
Well it does and the darn truck won't start. Starter battery flat as a pancake.
Has anyone else experienced this. Am I doing something wrong? I thought it was all automatic...
Thanks! 2015 110 XS CSW Montalcino Red with Black Pack
Post #642658 8th Aug 2017 9:47pm
zsd-puma
Is your starter battery any good? I mean is it actually taking a full charge?
Post #642669 8th Aug 2017 11:56pm
Caterham
Is the aux battery flat too or just starter battery?
Ie is it all connected up correctly?
Post #642698 9th Aug 2017 7:04am
acuss01
Yeah both batteries normally show voltage when you hit the 'display' button.
Good question Caterham about checking if the AUX battery is actually flat (ie if they are wired the right way round).
Since this upgrade was supplied and fitted by a site sponsor I assume it would be, but need to rule that out I guess!
For now I just want to be clear that its not a switch or button I am missing that sets the starter battery to be isolated. Its automatic I thought...
You only press 'Link' button if you want to manually override the isolation and link them together for extra power (eg winch) 2015 110 XS CSW Montalcino Red with Black Pack
Post #642710 9th Aug 2017 8:59am
dantastic
We've had a lot of trouble with the Odysseys on the challenge trucks in my club. They measure the correct voltage over the terminals but they are flat as pancakes.
Have someone measure the voltage (with a multimeter) as you try to crank. My guess is you'll see the voltage drop quite a lot, like 6-10v.
Could be wiring as well obviously but the story certainly quacks like a familiar duck....
Post #642731 9th Aug 2017 10:26am
jst
Next time you leave it why not disconnect the starter of Battery. And see. What's the charges like in the aux. And starter battery 3 days later. Compare that with leaving it connected. Odysseys aren't quite what they used to be, likewise seen quite a few issues with them on challenge scene lately Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #642768 9th Aug 2017 2:43pm
