Home > For Sale & Wanted > [Wanted] Td5 injector puller
Alextd5
United Kingdom 2006 Defender 90 Td5 XS CSW Bonatti Grey
Hi my friend is after a genuine Land Rover td5 injector puller. Part number Lrt-12-154/1 I have ordered one from dingocroft but not sure if it will be genuine or a copy.
Post #641988 5th Aug 2017 8:49am
Dieselhead
Small pry bar works a treat Whistle Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #642004 5th Aug 2017 10:36am
Fatboy Slim
Wales
Alex the puller is a complete waste of money. I must have done hundreds and hundreds of Td5 injectors and a small heel bar works much better
Post #642038 5th Aug 2017 4:05pm
4wd-junky
A long 4mm allen key works perfect. Thumbs Up
Post #642042 5th Aug 2017 4:34pm
Alextd5
Cheers,
The reason i was going to use the correct tool is down to hearing horror stories of cracking heads using bars!? BUT yea they are expensive so i would prefer to avoid using it.
Alex
Post #642046 5th Aug 2017 4:56pm
4wd-junky
You wont crack the head with a 4mm allen key, as it will flex slightly before the injector releases.
Post #642186 6th Aug 2017 9:42am
Alextd5
Thanku. I will give that a try. Last do I require Timing pin To lock cam?
Post #642211 6th Aug 2017 11:32am
4wd-junky
A locking pin is not necessary as you will need to rotate the camshaft by turning the crankshaft clockwise to create clearance at each injector before you can remove that injector, it will be obvious when you start.
Also, before you start removing the rocker shaft you will need to unscrew each of injector plunger adjusting screws a few turns to allow for correct adjustment during reassembly.
When removing the rocker shaft release each bolt evenly to avoid distorting the rocker shaft.
Post #642226 6th Aug 2017 1:08pm
