Home > For Sale & Wanted > [Wanted] Td5 injector puller |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 |
Small pry bar works a treat Chris
2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
5th Aug 2017 10:36am |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
Alex the puller is a complete waste of money. I must have done hundreds and hundreds of Td5 injectors and a small heel bar works much better
5th Aug 2017 4:05pm |
4wd-junky Member Since: 31 Aug 2014 Location: UK Posts: 89 |
A long 4mm allen key works perfect.
5th Aug 2017 4:34pm |
Alextd5 Member Since: 11 Feb 2017 Location: Gloucestershire Posts: 322 |
Cheers,
The reason i was going to use the correct tool is down to hearing horror stories of cracking heads using bars!? BUT yea they are expensive so i would prefer to avoid using it. Alex |
5th Aug 2017 4:56pm |
You wont crack the head with a 4mm allen key, as it will flex slightly before the injector releases.
6th Aug 2017 9:42am |
Thanku. I will give that a try. Last do I require Timing pin To lock cam?
6th Aug 2017 11:32am |
A locking pin is not necessary as you will need to rotate the camshaft by turning the crankshaft clockwise to create clearance at each injector before you can remove that injector, it will be obvious when you start.
Also, before you start removing the rocker shaft you will need to unscrew each of injector plunger adjusting screws a few turns to allow for correct adjustment during reassembly. When removing the rocker shaft release each bolt evenly to avoid distorting the rocker shaft. |
6th Aug 2017 1:08pm |
