Home > My Defender > My V8 110
Page 2 of 2 <12
V8_110
United Kingdom 1986 Defender 110 V8 Petrol CSW Corris Grey
Would a stage one grille and headlight surrounds be a direct fit?
Sam
Post #642027 5th Aug 2017 2:47pm
V8_110
Would a stage one grille and series 3 headlight surrounds be a direct fit?
Post #642028 5th Aug 2017 2:47pm
Essentially, yes. There will be some holes to fill from where the 110 grill mounts but the biggest problem is that proper Stage 1 grills are like hens teeth. There are also some small brackets for securing the bottom edge required, from memory. It was about 18 years ago that I made the change although ironically, on a genuine Stage1 that the previous owner had fitted a 110 grill to Rolling Eyes Darren
Post #642106 5th Aug 2017 9:13pm
V8_110
thanks for that.
The stage one grill that I found was re-manufactured but that shouldn't make a difference I hope.
Post #642505 7th Aug 2017 11:30pm
V8_110
Retroanaconda wrote:
You'll need to swap door strikers and potentially drill some holes in the pillars if going to push-button doors. All the internals and the door cards etc. will also be different so make sure your new doors come with those bits. The lift-up handle one-piece ones like yours fetch decent money, even knackered, so don't scrap them.
Looks like I'll stick with the lift up handles Thumbs Up
Post #642506 7th Aug 2017 11:33pm
V8_110
The middle row doors are too far gone so it looks like I will have to replace them and since replacing them with push button doors would require alot more work I've found these
https://www.sp-4x4.com/DEFENDER_SERIES_DOO...fconv2.htm
My main concern is security, would it be reduced with these windows?
I decided to go with an svx front end with 95mm LED's in the back
Does anyone here have any experience with the powerfulUK svx style front light kit?
Post #675449 3rd Jan 2018 5:09pm
V8_110
Long overdue update.
The middle donors that were described as top far gone have since been repaired by a professional welder. It now has a front svx kit.
I have also bought a 4.6 rv8 so now need to find an insurer that doesnt mind having a 20 year with a big V8
Pictures are on the way
Post #744040 4th Dec 2018 6:47pm
Procta
brentacre insurance should help you, as they insured my VVC metro i had, which was lot faster, Thumbs Up They also insured my defender, so they may see it as not been all that quick, I don't know how fast these are due to the weight. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #744043 4th Dec 2018 6:50pm
Page 2 of 2 <12
