Home > Technical > Headlights turn themselves off whilst driving....
heapster
On my TD5 110 the headlights have just started turning themselves off after about a minute - completely off including all the dash lights. Sidelights work fine but nothing from the headlights including the full beam (although the full beam flash still works). A few minutes later the headlights will all work again for a minute or so then the cycle repeats. I can't think that it's a fuse problem as it seems to reset itself after a while rather then fail completely, nor a switch problem for the same reason. It's almost as if a trip circuit is blowing then resetting once cooled down.
Just thought I'd check before I send it into the workshop - does this sound familiar to anyone?
Post #64172 17th Mar 2011 11:15pm
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
Check the head light / side light switch on the steering coloum.
Post #64192 18th Mar 2011 7:52am
landy andy
As above
Andy
Post #64193 18th Mar 2011 7:55am
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
could be the relay on the way out! but also check for dry connections and bad earths. they coud be coming back on when you hit a bump which will restore a loose connection. BM52
Post #64194 18th Mar 2011 8:11am
heapster
Thanks - I'll take a look at the fusebox and the switch at the weekend to see if there's anything loose. The strange thing was it did this whilst driving on flat road and it seemed to trip at the same time, as if something was warming up and tripping off, then cooling off allowing it to work again. Plus there was no dimming, just on/off.
Thanks for the replies.
Post #64209 18th Mar 2011 9:41am
Usually headlight problems are caused by the switch on the column overheating and allowing the contacts to move around. Worth checking.
The swirch is of course supplied by Lucas - the Princeof Darkness.
Post #64229 18th Mar 2011 12:01pm
heapster
The switch is of course supplied by Lucas - the Princeof Darkness.
Many thanks - will pick up a replacement and see if that does the trick. Paddocks are showing £30 for a replacement and the dealer just quoted me £85 for a genuine part ("We don't sell Mickey Mouse spares, sir. It's probably failed because it's non-LR....").
Post #64239 18th Mar 2011 12:38pm
110SEB
I had something similar on my old 90. Check battery connectors are tight. They may just look tight but in fact be loose.
Post #64244 18th Mar 2011 12:50pm
heapster
So I just replaced the main headlight switch and that seems to have cracked it. The main beam contacts on the old switch seem to have melted a bit into their plastic support so I can see what the problem was.
Thanks to all for the advice - managed to avoid a trip to the garage which is always a bonus.
Post #64672 22nd Mar 2011 7:44am
Anderzander
I've been through a few of these - if you've bought a pattern part my experience is that it will fail sooner rather than later ... There is a third alternative though in that you can buy the Lucas part, which is the OE part. It's more money than the cheaper pattern ones but still a fraction of the land rover price.
Post #64685 22nd Mar 2011 8:52am
Out of interest, was it the the dip switch (the usual suspect) or the main lighting on/off switch?
Post #64696 22nd Mar 2011 11:31am
heapster
Anderzander - I ended up haing the LR part as it was pretty urgent and Mrs H was passing Caffyns so picked the one up they had in stock. Not sure if the old one was the original or a pattern part replacement (04 year).
Blackwolf - it was the main on/off switch. It looked like the contacts had sunk (melted?) into the plastic mounting so wasn't making the circuit any more.
Post #64823 23rd Mar 2011 8:03am
Interesting, more often than not it is the dip switch that does this - the contacts oxidize a little so that they generate more heat, the plastic softens, and the contacts move. Beats me how these switches ever worked in the days before headlight relays were used. Total crap design, but we love it because it's a Defender!
Post #64835 23rd Mar 2011 9:03am
heapster
Thanks - I was wondering what the root cause was. Looking forward to the dip switch failing soon.....
Post #64847 23rd Mar 2011 12:15pm
Anderzander
That's interesting - my experience is the opposite. I've come across endless failed main light switches! Shocked
Post #64870 23rd Mar 2011 7:15pm
