Home > Maintenance & Modifications > Recaro Seat - Disappointed
Grenadier
Just a quick post on my D/S Recaro which, after just over a year, has developed a fault.
Fitted in May of last year I have loved the seats from the day I popped them in, on short and long drives alike. Super comfortable and far better than my previous Corbeaus (IMHO). But at a grand a pop, by no means cheap.
So, whilst I have loved their comfort and felt they were 'worth every penny' it comes as disappointment that after just over a year's use the D/S seat's springs now make a noise. Not a squeak, more a grate and evident over every small bump, movement in the road, even on a bend (of which there are many here in the Alps!!). Did a four hour drive recently and it was irritating beyond belief.
As far as usage is concerned, the DC is my daily runner, averaging probably 1.5hrs use a day, all on well-maintained tarmac roads. Further, whilst I'm no featherweight, at between 83-85kgs I'm not that heavy either. And I am religious about keeping them clean and never kneel on them with my knee if leaning across the cabin etc.
I appreciate that Def ownership is all about little niggles and problems, certainly noises, but I'm not a little irked that my most expensive single upgrade, reputed to offer the best quality, has developed such a small, yet irritating, fault in just a year.
Has anyone else had the same problem (so quickly) and should I contact the supplier or are Recaro a bit like Giro (Helmets) and always want faulty items returned direct due to their high production standards?
Thoughts, experiences, advice, sarcastic comments (that I should have the OE seats...) welcomed! Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #641562 3rd Aug 2017 11:13am
bankz5152
Bit of grease? Loose bolt?
My Corbeaus had a couple bolts work loose where they recline, made a similar annoying noise. Tightened em up and got rid of it
Post #641571 3rd Aug 2017 11:34am
Grenadier
Did wonder that actually. Will be taking it out this week for a gander. Monsieur Le Grenadier
Post #641572 3rd Aug 2017 11:48am
ericvv
DS Recaro. That's something very different than the genuine SVX Recaro, no?
Sell them again, add another grand, or a bit more, a pop, and enjoy the real thing.
Mine stay quiet, even after 9 years.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #641595 3rd Aug 2017 1:45pm
I took DS to mean 'drivers side'. Darren
Post #641600 3rd Aug 2017 1:55pm
Grenadier
^^^That's why you're a self-confessed anorak. Driver's Side it is... Thumbs Up Monsieur Le Grenadier
Post #641605 3rd Aug 2017 2:08pm
Grenadier
Eric
Real thing, still making a noise Big Cry Monsieur Le Grenadier
Post #641606 3rd Aug 2017 2:08pm
ericvv
You must mean a Recaro C/S then, the Recaro DS seems a completely different seat. The DS is older, looks more like a Scheelman seat. Try contacting Recaro and explain, see what they say.
Post #641619 3rd Aug 2017 2:57pm
Grenadier
The Seat is an SVX. But it's the Driver's Side (DS) seat. Sorry Eric, lost in translation. Whistle Monsieur Le Grenadier
Post #641626 3rd Aug 2017 3:22pm
Pickles
We had a Focus RS Mk 11 (2.5L Turbo), which had recaro seats, which creaked in the backrest/hinge area after a while. It was some time ago, but from memory I think the Dealer greased the area, which fixed it.
Pickles.
Post #641786 3rd Aug 2017 10:58pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
I didnīt realise the Recaros had springs, but will take a closer look at mine.
Where is the noise coming from? Backrest or base?
Picking up on bankzīs suggestion, mine became noisy after about a year. It turned out to be loose bolts that fix the backrest to the recliner mechanism. Not Recaroīs fault, but when the seats were reassembled after painting the backrests, the bolts needed a little loctite. Check as well the bolts on the seat runners and from those to the seat box. There really arenīt many things on those seats that can make noises.
Stephen 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #641810 4th Aug 2017 5:48am
Grenadier
^^ Thanks WC90, it is hard to say where it's coming from, as it only happens whilst driving so under order from Mrs Grenadier I 'keep my eyes on the road'!! But I do think it might be somewhere between base and back, so the hinge as you and others have pointed out, might be it.... Thumbs Up Monsieur Le Grenadier
Post #641814 4th Aug 2017 6:42am
Wild Card 90
Glad to help, but do let us know once you find the culprit!! 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #642061 5th Aug 2017 6:37pm
dgardel
Italy
Re: Recaro Seat - Disappointed
More than 3 years of usage on mine (I'm 1,83m by 98kg) no problem at all with my Recaro (yet Whistle ) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #642066 5th Aug 2017 6:57pm
