Home > Technical > Gearbox off - DIY job?
hank
As per previous threads I have a leaking crank main seal and am toying with the idea of doing it myself and changing the clutch and various other bits while I'm at it (http://www.defender2.net/forum/topic56024.html)
Is this a side of the road DIY job? I'm a fairly competent spannerer having stripped a few cars to a bare shell and rebuilt. Defender is my second vehicle so no immediate rush.
Post #641349 2nd Aug 2017 10:24am
srod
I did mine on my drive, over a weekend, pretty much on my own, with occasional help from the missus to operate lifting gear and the use of a child here and there to fetch and pass spanners etc.
Depending on how busy the road is, I'd say yes. You'll probably need access from the side with an engine crane or jack.
Post #641354 2nd Aug 2017 10:51am
No reason why it shouldn't be. You will need to raise the vehicle a certain amount to create enough clearance to get the gearbox out from underneath (I park mine on blocks for this). I would also recommend taking the transfer box off the gearbox first, the the gearbox off the engine. Remember that you are lifting heavy components above you, either the t-box or gearbox is heavy enough to cause life-changing injuries if you drop it on yourself, so be sensible.
I use a gearbox jack for lowering the boxes, but many people use an engine crane through the floor. Either approach works well.
It is not a job for the feint-hearted, but it is not difficult. You will need a clutch aligning tool, of course.
Post #641355 2nd Aug 2017 10:53am
miker
Agreed with above. It's hard work, and heavy, but achievable at side of road. Currently doing a friends in the alleyway behind his house!
Post #641450 2nd Aug 2017 7:34pm
