![]() | Home > Technical > Puma Clutch prices |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4761 ![]() ![]() |
Land Rover Defender 2007 Clutch Kit Part No.: LR012199 comes in at £234.82(+VAT at 20%) from your maindealer.
Paddocks have AP Driveline (formerly Borg and Beck) Clutch Kit (plate and cover) - TDCI Puma Part Number: LR012199G for £139.38 Inc. VAT. That is the exact same part number. Paddocks also list this one from (Please don't shoot me) Britpart, Uprated Clutch Kit - Plate & Cover - Defender Puma 2007 onwards LR072972 for £146.88 Inc. VAT. And they go on to say" The uprated clutch kit for Defender Puma was originally introduced by Land Rover for the higher powered Autobiography model. Britpart have now introduced this kit to enable you to fit a heavier duty clutch to your regular powered Puma" Here are a list of clutch part numbers that have been used for the Puma LR029894 - LR005772 - LR037956 - LR012199 - URB500080 The only one that comes up in searches on a maindealer site is the LR012199, so I presume that is the standard issue from Land Rover now....unless you go for the super doper heavy duty one. This does not come up on the maindealer site. I'm off to get a life now... 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
I would speak to Ben Williams at clutchfix and get a decent clutch sorted not much more and higher quality for most the hd1 ceramic clutch kit will do or has higher power applications available I have a hd1 in mine and it's lighter and smoother than the original worth the few extra quid in my opinion 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
proloForêt Member Since: 16 Mar 2017 Location: Montereau Posts: 248 ![]() ![]() ![]() |
pj, how is the hd1 clutch in regards noise especially when idling in neutral?
Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 618 ![]() ![]() |
Not long fitted the britpart uprated clutch. It was stamped AP.
Seems good. It's spent it's entire life so far (about 500-750 miles) dragging a fully loaded 110 plus a caravan of 1.6 tonne about. There is a slight clutch rattle on idle when hot, but I have heard of this with other clutches too, including clutchfix ones. V8 90...WIP |
