Home > Maintenance & Modifications > Leaking oil and loose hub nuts
kweese
Canada 1999 Defender 110 Td5 SW Belize Green
I noticed a few weeks ago my center cap for my wheel fell off. I drove a few hundred kilometers and today I noticed a bit more oil leaking on my tires. As in the pictures. Upon closer inspection. The bolts inside are all loose.
What could be wrong?
How did these bolts all get loosened?
Post #640464 29th Jul 2017 7:46am
dorsetsmith
spring washers or thread lock
my has 03 90 has spring washers fitted, but 06 pickup no spring washers fitted and thread lock used
Post #640467 29th Jul 2017 8:04am
kweese
Thats it?? I can clean it with brake cleaner and apply thread lock to the bolts?
Post #640468 29th Jul 2017 8:07am
Yup, although you might want a new gasket too. I recently had to replace a gasket on one of mine and it's quite simple.
I had drained the axle oil though. If you're not doing that then you'll need to jack it up reasonably high to stop the oil pouring out of the end! Darren
Post #640469 29th Jul 2017 8:16am
kweese
I'm going on a 200 km road trip tomorrow.. I was reading that I need to check something using a bracket dial clamp?? is this necessary?
Post #640474 29th Jul 2017 8:22am
kweese
NO GOOD!! I just took the wheel off and all the bolts are broken.. sheared off the hub. Rolling Eyes
Post #640480 29th Jul 2017 9:20am
Balvaig
Happened to me a few years back. Guessing that they are broken inside and not protruding. If you are lucky then you can drill and use a bolt removal tool. Not a quick fix though - took me a whole morning of cursing and swearing!
Post #640497 29th Jul 2017 11:05am
agentmulder
Kuwait
The flange connects the halfshafts/CVs to the wheel and should have nothing directly to do with the operation of the wheel bearing/wheel nuts/stub axle assembly (which various (older) WSMs dictate that you must check for play using a dial test indicator).
So, to answer your question directly: no.
Personally, after the frustrating session you're about to have with a set of 'easy'-outs ( Rolling Eyes ) I'd be inclined to open it all up and have a look. Rear is easy and worth doing for that reason, front a bit more involved, but with a loose flange the splined/driving end of the CV will have been floating and conceivably placing loads on internal bearing, thrust washers and seals that it wouldn't normally.
I'm not a mechanic, so as always, I'm interested to learn if my advice is valid Wink Solved the bowel problem, working on the consonants...
Post #640502 29th Jul 2017 11:38am
kweese
Parts
I live in Canada, and it's not easy to get parts from dealerships here. I was able to get the hub from a friend who works at Land Rover. What other parts should I get? Also, if i'm doing this i might as well do the bearings? I notice there are kits for Disco 1 and Range Rover Classics which I am able to get parts for here. Would those be the same? I'm noticing that at paddocks and John Craddocks the kit numbers are different, but the bearings appear to be the same part numbers.
Chris
Post #641045 1st Aug 2017 3:15am
Mo Murphy
The wheel bearings are the same Chris, for RR classic, Disco 1 and Defender.
You'll need a hub seal, drive flange gasket, locking washer for the hub lock nut. Bolts are nothing special, get them from your local supplier, use spring washers (double check there's no interference on the inside of the alloy wheel when you refit it), tighten drive flange bolts to 65nm torque.
HTH
50 Shades of Pennine Grey
Post #641081 1st Aug 2017 7:51am
Balvaig
I seem to recall that the bolts are heavy duty 10.9 grade.
Post #641247 1st Aug 2017 7:58pm
