Home > Maintenance & Modifications > Leaking oil and loose hub nuts |
kweese Member Since: 28 Apr 2015 Location: Van Posts: 62 |
I noticed a few weeks ago my center cap for my wheel fell off. I drove a few hundred kilometers and today I noticed a bit more oil leaking on my tires. As in the pictures. Upon closer inspection. The bolts inside are all loose.
Click image to enlarge What could be wrong? Click image to enlarge Click image to enlarge How did these bolts all get loosened? |
29th Jul 2017 7:46am |
Thats it?? I can clean it with brake cleaner and apply thread lock to the bolts?
29th Jul 2017 8:07am |
Yup, although you might want a new gasket too. I recently had to replace a gasket on one of mine and it's quite simple.
I had drained the axle oil though. If you're not doing that then you'll need to jack it up reasonably high to stop the oil pouring out of the end! Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
29th Jul 2017 8:16am |
I'm going on a 200 km road trip tomorrow.. I was reading that I need to check something using a bracket dial clamp?? is this necessary?
29th Jul 2017 8:22am |
NO GOOD!! I just took the wheel off and all the bolts are broken.. sheared off the hub.
29th Jul 2017 9:20am |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 733 |
Happened to me a few years back. Guessing that they are broken inside and not protruding. If you are lucky then you can drill and use a bolt removal tool. Not a quick fix though - took me a whole morning of cursing and swearing!
29th Jul 2017 11:05am |
The flange connects the halfshafts/CVs to the wheel and should have nothing directly to do with the operation of the wheel bearing/wheel nuts/stub axle assembly (which various (older) WSMs dictate that you must check for play using a dial test indicator). So, to answer your question directly: no. Personally, after the frustrating session you're about to have with a set of 'easy'-outs ( ) I'd be inclined to open it all up and have a look. Rear is easy and worth doing for that reason, front a bit more involved, but with a loose flange the splined/driving end of the CV will have been floating and conceivably placing loads on internal bearing, thrust washers and seals that it wouldn't normally. I'm not a mechanic, so as always, I'm interested to learn if my advice is valid Solved the bowel problem, working on the consonants... |
29th Jul 2017 11:38am |
I live in Canada, and it's not easy to get parts from dealerships here. I was able to get the hub from a friend who works at Land Rover. What other parts should I get? Also, if i'm doing this i might as well do the bearings? I notice there are kits for Disco 1 and Range Rover Classics which I am able to get parts for here. Would those be the same? I'm noticing that at paddocks and John Craddocks the kit numbers are different, but the bearings appear to be the same part numbers.
Chris |
1st Aug 2017 3:15am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2267 |
The wheel bearings are the same Chris, for RR classic, Disco 1 and Defender.
You'll need a hub seal, drive flange gasket, locking washer for the hub lock nut. Bolts are nothing special, get them from your local supplier, use spring washers (double check there's no interference on the inside of the alloy wheel when you refit it), tighten drive flange bolts to 65nm torque. HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
1st Aug 2017 7:51am |
I seem to recall that the bolts are heavy duty 10.9 grade.
1st Aug 2017 7:58pm |
