Home > Technical > td5 creaking clutch |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 507 |
Unscrewing the 6 screws and taking off the cover plate will give you access to the moving parts inside the pedal box so you may be able to get some oil in there? Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
30th Jul 2017 6:19pm |
greasegun2 Member Since: 20 Apr 2017 Location: Norfolk Posts: 3 |
Thanks Matt,
I have oiled in there and even fitted a grease nipple into the shaft. I do believe its further down the line. Thanks for the reply. |
30th Jul 2017 6:31pm |
This thread may be helpful, although you say you have done the grease nipple mod. Have you tried lithium grease?
http://www.defender2.net/forum/topic45191-15.html Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
30th Jul 2017 6:54pm |
Thanks,
I have just taken another look at it, im sure its near the slave cylinder or inside the box. |
30th Jul 2017 7:32pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2672 |
Probably the release arm on its pivot inside the bellhousing. Mine does it too, though I can't hear it when driving.
The pivot and arm can wear, so replacement if necessary and a good helping of grease next time you're fiddling inside the bellhousing should sort it. |
30th Jul 2017 7:49pm |
