Home > Technical > V8 CSW Rear Spring Recommendations?
skwdenyer
United Kingdom 1987 Defender 110 V8 Petrol CSW Alpine White
Hi there. Long-time lurker, finally got my long-broken 1987 V8 110 CSW back on the road, now need to keep the momentum up with a "rolling restoration." So after a little help.
My rear springs are corroded. They also seem a little "settled" - the stance just doesn't seem quite right.
Looking around, it seems to me that more recent Defenders have a "tail up" stance whereas older ones appear to sit flatter, dipping under load.
What is the current state of the art thought-wise on what replacement springs to use? Should I be looking for the "tail up" stance (which I admit seems to suit the beast) and, if so, am I looking at complete replacement of all 4 springs to achieve that safely?
Thanks!
Post #639153 23rd Jul 2017 2:47pm
Retroanaconda
Early CSW vehicles such as yours used a soft rear spring and a Boge hydraulic damper thing which 'pumped' the rear end under load. These generally fail after a while and if the rear springs sag with age the vehicle will sit arse-down. It should sit level with everything working okay. This was a good setup but the struts failed in time.
Because of the general rubbish-ness of the self-levelling strut thing on later models Land Rover did away with it and used progressive springs on the rear, these are a compromise between soft springs for a good ride and stiff ones for load carrying. One of the side effects of this is the arse-up attitude that you describe.
Your simplest option is to just fit the later progressive SW springs. However as I prefer the nicer ride I will be refitting the soft early springs and using airbag helpers to replace the function of the levelling strut.
Post #639160 23rd Jul 2017 2:55pm
skwdenyer
Thanks for that. So perhaps I need to run it about a bit and see if the Boge unit is actually screwed? I've only just got it back to MOT standard (a long way to go to where I want to be, but at least can drive).
Are the Boges rebuildable / replaceable? Right now I have an original CSW and, whilst not an "authenticity nut," I quite like the idea of keeping things as standard as possible (not least because, given where I live, insurance is a headache and I only want to go down the modifications route for things that I *really* want).
Thanks again
Post #639164 23rd Jul 2017 2:59pm
Retroanaconda
I'm not sure they're still available new. I've heard of people trying to rebuild them with no success.
Put some weight in the back - enough to drop the suspension a bit - and measure the height to the rear door threshold (or similar). Then go for a drive and remeasure, the self-levelling strut should pump it back up to standard height. If it doesn't then it's knackered.
Post #639183 23rd Jul 2017 4:08pm
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
OME Repacement suspension parts..
Post #639555 25th Jul 2017 5:41am
