![]() | Home > For Sale & Wanted > [Wanted] Puma 2.4 TDCI EGR blanking plate |
try ebay, about £3
Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461 ![]() ![]() ![]() |
Make your own with a Coke can. 10 minutes max.
4wd-junky Member Since: 31 Aug 2014 Location: UK Posts: 89 ![]() ![]() |
Thanks bpman, can't find one on ebay that fits at exhaust manifold/EGR cooler joint?
Thanks Lightningtweeds, will make one if none available here. |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
I've got one that was in a 2.2, not sure about 2.4 fitment?
Should be the same? ![]() Click image to enlarge 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Thanks Ian, was that one fitted here?
Yep
![]() Wanted, Forward Control Anything considered. |
Dean Watson Member Since: 17 Jul 2011 Location: Derby Posts: 261 ![]() ![]() ![]() |
hi mate
egr delete on ebay £3.85 inc postage http://www.ebay.co.uk/itm/EGR-blanking-pla...1475129633 Cheers |
Thanks Ian, sent you a PM.
Thanks Dean, looked at those, but it looks like they're designed to be fitted at the EGR valve and not the exhaust manifold. |
proloForêt Member Since: 16 Mar 2017 Location: Montereau Posts: 248 ![]() ![]() ![]() |
why would it be put to there and not at egr valve?
Hi proloForêt
If the plate is fitted at the EGR valve, the EGR cooler could possibly get blocked with soot and would need cleaned if the EGR was to be made operational again. Blanking the entry to the EGR cooler prevents the cooler from getting blocked. |
I've just sent you a pm, looking at the link that's now been posted, mine is the same as that!
So you may not want it... ![]() Wanted, Forward Control Anything considered. |
Thank you to explain this. OK this seem to me a good idea to me. Is the cooler attached to the exhaust so the soot now continue it exit out that way instead? I believe mine has at egr valve but is this shape plate. My egr is switched off by a remap from Alive but sometimes on switch off I hear the chuggy-chuggy noise. |
Hi proloForêt
No, the EGR cooler is redundant when blanked and the EGR is disabled. All the engine combustion gases now exit through the turbocharger into the exhaust. ![]() ![]() Click image to enlarge Item Part Number Description 1 - Turbocharger assembly 2 - Exhaust manifold 3 - EGR cooler The EGR system directs exhaust gases into the inlet manifold to be used in the combustion process. The principal effect of this is to reduce combustion temperatures, which in turn reduces Nitrous Oxide (NOx) emissions. |
