Home > For Sale & Wanted > [Wanted] Puma 2.4 TDCI EGR blanking plate
4wd-junky
Looking a Puma 2.4 TDCI EGR blanking plate that fits between the exhaust manifold and EGR cooler.
What have you?
Thanks for looking. Thumbs Up
Post #638577 20th Jul 2017 10:39am
try ebay, about £3
Post #638578 20th Jul 2017 10:49am
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
Make your own with a Coke can. 10 minutes max.
Post #638581 20th Jul 2017 10:52am
4wd-junky
Thanks bpman, can't find one on ebay that fits at exhaust manifold/EGR cooler joint?
Thanks Lightningtweeds, will make one if none available here.
Post #638583 20th Jul 2017 11:00am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I've got one that was in a 2.2, not sure about 2.4 fitment?
Should be the same?
 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #638589 20th Jul 2017 11:17am
4wd-junky
Thanks Ian, was that one fitted here?
Post #638592 20th Jul 2017 11:23am
ian series 1
Yep Thumbs Up 80" 80" 86" 88" 90"
Post #638599 20th Jul 2017 12:02pm
Dean Watson
United Kingdom 2011 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
hi mate
egr delete on ebay £3.85 inc postage
http://www.ebay.co.uk/itm/EGR-blanking-pla...1475129633
Post #638611 20th Jul 2017 12:42pm
4wd-junky
Thanks Ian, sent you a PM.
Thanks Dean, looked at those, but it looks like they're designed to be fitted at the EGR valve and not the exhaust manifold.
Post #638614 20th Jul 2017 1:05pm
proloForêt
France 2008 Defender 90 Puma 2.4 XS CSW Java Black
why would it be put to there and not at egr valve?
Post #638617 20th Jul 2017 1:13pm
4wd-junky
Hi proloForêt
If the plate is fitted at the EGR valve, the EGR cooler could possibly get blocked with soot and would need cleaned if the EGR was to be made operational again.
Blanking the entry to the EGR cooler prevents the cooler from getting blocked.
Post #638620 20th Jul 2017 1:22pm
ian series 1
I've just sent you a pm, looking at the link that's now been posted, mine is the same as that!
So you may not want it... Wink 80" 80" 86" 88" 90"
Post #638622 20th Jul 2017 1:33pm
proloForêt
4wd-junky wrote:
Hi proloForêt
Thank you to explain this. OK this seem to me a good idea to me. Is the cooler attached to the exhaust so the soot now continue it exit out that way instead?
I believe mine has at egr valve but is this shape plate. My egr is switched off by a remap from Alive but sometimes on switch off I hear the chuggy-chuggy noise.
Post #638691 20th Jul 2017 8:20pm
4wd-junky
Hi proloForêt
No, the EGR cooler is redundant when blanked and the EGR is disabled.
All the engine combustion gases now exit through the turbocharger into the exhaust. Very Happy
Item Part Number Description
1 - Turbocharger assembly
2 - Exhaust manifold
3 - EGR cooler
The EGR system directs exhaust gases into the inlet manifold to be used in the combustion process. The principal effect of this is to reduce combustion temperatures, which in turn reduces Nitrous Oxide (NOx) emissions.
Post #638713 20th Jul 2017 9:41pm
