Home > Puma (Tdci) > Black smoke and funny noise!!!! |
arran jones Member Since: 21 Nov 2016 Location: south west Posts: 726 |
Sorry 50mph not mpg!
All help will be greatly received |
15th Jul 2017 5:05pm |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
Sounds to me like the intercooler hose has split, relatively simple fix.
15th Jul 2017 5:13pm |
Ok thanks so much
Wouldnt of thought that would make the exhaust do that but will check.... Can i check if its split by just looking inside the engine??? |
15th Jul 2017 5:24pm |
The black smoke is due to over-fuelling because of lost boost (air) pressure to the engine, the whistling noise will be the sound of the turbo "escaping" from the split pipe.
Should be able to locate it fairly easy, look or feel along the thickish pipes from the turbo to the intercooler and intercooler to throttle body, you might find an oily patch along there where the leak is. You could even find one of them has just slipped off at one end if it's not been secured properly |
15th Jul 2017 5:34pm |
proloForêt Member Since: 16 Mar 2017 Location: Montereau Posts: 248 |
It is more commonly true than in a diesel engine black smoke in exhaust is from fuel not oil. Too much fuel will mean smoke.
15th Jul 2017 5:36pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2751 |
Yep you should be able to find it with a bit of a poke around the engine bay. Engine running and a torch, most likely location is the hose which runs close to the steering column thingy (sorry don’t know the proper name) on the right hand side of the car looking forwards, left side as you look backwards from the front.
The steering column can gradually rub through the hose, as happened to me. Hole in hose = whistle, plus lack of boost means overfueing = black smoke.. Hope that helps! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
16th Jul 2017 11:30am |
Yes helps alot
16th Jul 2017 2:11pm |
