Home > Puma (Tdci) > Black smoke and funny noise!!!!
arran jones
Hello All
On my way bak from fairford in my 90 yesterday and suddenly the engine started making rough whisling noises and loads of black smoke coming out of the exhaust at around 2000-above revs and 50+mpg below that was fine
So i stopped thinking of the worse!!
And it was steaming like crazy and the exhuast pipe under the chassis! Engine temp all fine
On a cold engine it does the same but white smoke
It has got a oil leak in the engine somewhere but dont know wheather that would be something to do with it....
Can anyone throw some good ideas across because i dont really want to drive it until it sorted
Many thanks
Arran jones
Post #637682 15th Jul 2017 5:03pm
arran jones
Sorry 50mph not mpg!
All help will be greatly received
Post #637684 15th Jul 2017 5:05pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
Sounds to me like the intercooler hose has split, relatively simple fix.
Post #637686 15th Jul 2017 5:13pm
arran jones
Ok thanks so much
Wouldnt of thought that would make the exhaust do that but will check....
Can i check if its split by just looking inside the engine???
Post #637687 15th Jul 2017 5:24pm
Clive
The black smoke is due to over-fuelling because of lost boost (air) pressure to the engine, the whistling noise will be the sound of the turbo "escaping" from the split pipe.
Should be able to locate it fairly easy, look or feel along the thickish pipes from the turbo to the intercooler and intercooler to throttle body, you might find an oily patch along there where the leak is.
You could even find one of them has just slipped off at one end if it's not been secured properly
Post #637689 15th Jul 2017 5:34pm
proloForêt
France 2008 Defender 90 Puma 2.4 XS CSW Java Black
It is more commonly true than in a diesel engine black smoke in exhaust is from fuel not oil. Too much fuel will mean smoke.
Post #637690 15th Jul 2017 5:36pm
Cheshire110
Yep you should be able to find it with a bit of a poke around the engine bay. Engine running and a torch, most likely location is the hose which runs close to the steering column thingy (sorry don’t know the proper name) on the right hand side of the car looking forwards, left side as you look backwards from the front.
The steering column can gradually rub through the hose, as happened to me.
Hole in hose = whistle, plus lack of boost means overfueing = black smoke..
Hope that helps! Thumbs Up Cheers, David
Post #637785 16th Jul 2017 11:30am
arran jones
Yes helps alot Thumbs Up
Post #637808 16th Jul 2017 2:11pm
