Home > Maintenance & Modifications > Foot well replacement (Driver side) RHD Defender 110 97
itolond
Singapore 1997 Defender 110 300 Tdi SW Alpine White
Hi Forum,
I have been searching without much luck on how to go about removing the old footwell.
I have thus far, removed all the bolt on bits, cables grommets its so its clear- it the foot well welded and needs cutting or is it auto adhesive ?
anyways pointers and red-flags welcome
Post #637244 13th Jul 2017 7:34am
It's an integral welded part of the bulkhead. Darren
Post #637256 13th Jul 2017 9:20am
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
If still the original footwell then I think it will be spot welded in, if so and you can still see the spot welds buy a spot weld drill bit.
Post #637264 13th Jul 2017 9:58am
itolond
Ok got it its a cut out situation.
given responses- i am guessing a riveted installation is ok ( sealed of course)
Post #637299 13th Jul 2017 1:44pm
Retroanaconda
No, it will need to be welded. The pedal boxes and steering all attach to it and so it needs to be rock solid.
Cut out the old one, then seam-weld in a replacement.
Post #637306 13th Jul 2017 2:47pm
