Home > Technical > Central Lock kit/alarm
okami
United Kingdom 1993 Defender 110 200 Tdi SW Montpellier Red
Tried searching, but didn't find much useful.
Found a lot of different cheap flea-bay vendors selling central lock kits, some of which are advertised for Defenders. Any recommendations on particular brands? Any thing to stay away from?
It would be nice to have one integrated with an alarm. I already have the door plungers (actually two sets for some reason) and an alarm installed, but my truck didn't come with the fob so I'm pulling out the mystery alarm soon.
-okami
Post #637052 11th Jul 2017 9:58pm
bankz5152
Hawk do a good central locking kit, I retrofitted it on my 02 90.
As for tying it into the alarm I don't know on other types but on the TD5 you can buy a lil relay off ebay (£15) to solder on to the 10AS alarm unit then activate central locking via a Nanocom. Or you can send your 10AS unit away for the relay to be soldered on for a bit more.
If its an older model then I believe Hawk do an all inclusive unit with an alarm system.
Post #637106 12th Jul 2017 10:32am
okami
Just bought a Hawk 2-way setup on ebay. We'll see how it goes!
Post #637182 12th Jul 2017 6:33pm
JWL
Plus 1 for the Hawk kit, over time it does succomb to the same problems as a genuine fitment in that the wires between the doors and pillars break through the constant flexing but with a bit of patience when fitting the solonoids and rods they will give years of service. One tip would be is to leave plenty of slack in the pillar so when you get any hassle with broken wires you can pull more out of the pillar and rejoin Thumbs Up
Post #637267 13th Jul 2017 9:22am
bankz5152
I had the exact same problem! My "solution" was to wrap the cables in braided nylon sheath and run the wires tight across the door stay, so the cable moved with the door stay and couldnt get jammed with minimal flexing.
Post #637271 13th Jul 2017 9:35am
