![]() | Home > Td5 > Vnt or twin turbo |
termohe Member Since: 23 Jul 2012 Location: De Pinte Posts: 15 ![]() ![]() ![]() |
For ecu maps talk to Simon Doherty. You can find him on FB.
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 ![]() ![]() ![]() |
Need a little more info, there are too many to select from...
Am more interested in the flashing programmer and program... I have the artic 3 from alive, but i dont see how i am able to map my ecu on my own |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3787 ![]() ![]() ![]() |
Definitely wouldn't be going twin turbo,..too complicated, too much to go wrong.
Might be OK in its original vehicle/installation etc, but to put it on another vehicle, no way. Pickles. |
2015 bmw 335dxi comes with twin vnt turbos...
Water cooled and ball bearinged... 😈😈😈 |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3653 ![]() ![]() ![]() |
have you looked at the BMW123 d twin set up it will be smaller than the 335d but they put out 205 bhp standard and much more tuned so should pump enough air. The engines have cam chain issues and have been around since 2007 so second hand parts are available? DEFENDER 90 TDCI XS,
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2655 ![]() ![]() |
Did you not consider a om606 etc if your so set on big power from turbo's etc?
Where i live diesels are not that popular.
Its hard enough findin parts for a Mack truck. Let alone a merc diesel engine assembly... Is it plug and play? As in it will bolt right up to the r380. |
Another option is to drop in a bmw 35d engine with engine harness and be done with it...
So i scored a deal on the twin turbo setup. And the small turbo is a VNT turbo.
I will buy the Billet compressor wheels once i get them in my hands, and then buy three electronic boost controllers. One will control the Small turbo for pressure, the second will control the compressor and turbo bypass, and the third will control the large turbo wastegate as not to over boost the engine. All via vacuum, so minimal changes to what was originally there. The VNT will be vacuum controlled and not electronic. This is to help keep everything as simple as possible... |
I think we need pictures..
Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 313 ![]() ![]() ![]() |
What information did you use to match the correct turbo sizes to the TD5 engine?
I found an engine displacemt slightly larger than ours and bought the whole kit.
I may still get the 2260vnt turbo. Less work and similar results... ![]() Click image to enlarge ![]() Click image to enlarge |
