Home > Td5 > Vnt or twin turbo
Page 2 of 2 <12
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
The bmw 335d twin power turbo needs vacuum lines to operate...bummer...Would have been a nice idea, but for the money its 200gbp above the x5 3.0d turbo.
Will scan fleabay for the best deal on the GTB2260V, best upgrade is its a ball bearing, and with a billet compressor wheel it aught to scream, will also score the actuator bracket from darksidedevelopment and have my fab guys piece together a bad ass header for the turbo. The modular stainless one on fleabay needs more work on its finish...The holes didnt quite line up and the inner parts need a good polishin to get rid of all the bottle necks and sharp edges.
Now lets talk ecu flashers, what brands work and what are their limitations
Post #636260 7th Jul 2017 6:09pm
termohe
Belgium 2004 Defender 90 Td5 HT Alpine White
For ecu maps talk to Simon Doherty. You can find him on FB.
Post #636261 7th Jul 2017 6:18pm
Naf
Need a little more info, there are too many to select from...
Am more interested in the flashing programmer and program...
I have the artic 3 from alive, but i dont see how i am able to map my ecu on my own
Post #636270 7th Jul 2017 6:50pm
Pickles
Definitely wouldn't be going twin turbo,..too complicated, too much to go wrong.
Might be OK in its original vehicle/installation etc, but to put it on another vehicle, no way.
Pickles.
Post #636316 7th Jul 2017 10:18pm
Naf
2015 bmw 335dxi comes with twin vnt turbos...
Water cooled and ball bearinged...
Post #636342 8th Jul 2017 5:18am
LR90XS2011
have you looked at the BMW123 d twin set up it will be smaller than the 335d but they put out 205 bhp standard and much more tuned so should pump enough air. The engines have cam chain issues and have been around since 2007 so second hand parts are available? DEFENDER 90 TDCI XS,
Post #636357 8th Jul 2017 7:19am
Likeomg
Did you not consider a om606 etc if your so set on big power from turbo's etc?
Post #636379 8th Jul 2017 9:34am
Naf
Where i live diesels are not that popular.
Its hard enough findin parts for a Mack truck. Let alone a merc diesel engine assembly...
Is it plug and play? As in it will bolt right up to the r380.
Post #636380 8th Jul 2017 9:40am
Naf
Another option is to drop in a bmw 35d engine with engine harness and be done with it...
Post #636402 8th Jul 2017 1:54pm
Naf
So i scored a deal on the twin turbo setup. And the small turbo is a VNT turbo.
I will buy the Billet compressor wheels once i get them in my hands, and then buy three electronic boost controllers.
One will control the Small turbo for pressure, the second will control the compressor and turbo bypass, and the third will control the large turbo wastegate as not to over boost the engine. All via vacuum, so minimal changes to what was originally there. The VNT will be vacuum controlled and not electronic. This is to help keep everything as simple as possible...
Post #637127 12th Jul 2017 12:28pm
Likeomg
I think we need pictures.. Shocked
Post #637141 12th Jul 2017 1:53pm
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
What information did you use to match the correct turbo sizes to the TD5 engine?
Post #637152 12th Jul 2017 2:45pm
Naf
I found an engine displacemt slightly larger than ours and bought the whole kit.
I may still get the 2260vnt turbo. Less work and similar results...
Post #639172 23rd Jul 2017 3:25pm
Page 2 of 2 <12
