![]() | Home > Puma (Tdci) > blower / a/c conundrum |
![]() Click image to enlarge ![]() Click image to enlarge |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
Thanks very much guys. Gonna hopefully find some time to have a look at this tonight / tomorrow. Thank you for the pointers.
Any idea where r181 I located? |
i may be wrong on 2.4 under driver seat
![]() Click image to enlarge now that's sorted, time for western vintage cider ![]() |
western vintage cider.......from Aldi? - very nice
![]() thanks for the info. If I turn the a/c button on I can hear the relay kicking in/out and the fan turn onto speed one (with the fan speed slider being in 'off' position which I believe is normal). suggests to me the control side of things is ok but the compressor isn't kicking in? EOS many thanks for; Check... Relay R181. Does it close when you press the AC button? If Yes - It is a compressor/clutch problem. so compressor / clutch problem. where can I start in terms of trying to resolve? |
check for 12VDC at the plug of compressor / clutch pin to pin in the plug
nothing between pins (well female pins) and nothing between either and earth?
back to the wiring diagram? .................. |
many thanks for this. is there any documents that explain what the various relays are for. having looked at the wiring diagram above it would appear the compressor / clutch relies on 2 replays (R117 and R181) - but where are they? |
R181 (C0712) red arrow and R117 (C0019) next one to back of the seat box
thanks Dorsetsmith but I'm stumped.....
I tested some of the relays and swapped numerous overall - all relays seem to be fine. No fuses blown for love n money can I find a 12V at the compressor? I've been disconnecting the two pin plug which is approx. half way between the compressor and injector / head cover. One of the wires being green / yellow. I've tried with engine running and just ignition on nothing at all. I did wonder if perhaps I'm not finding a suitable earth point but certainly everything I've shows nothing (I'd have at least expected to have seen something if the earth wasn't great? stumped ![]() ![]() |
work your way down cct with multimeter and test wiring and components, sounds like you open cct in the wiring test one two ways
1. test with multimeter cct live 2. test with multimeter point to point con check also rid temp 12v DC test the compresses |
/\ how do I test '1' with a multimeter? I've no idea where the switch / sensor would be for confirming there's pressure in the system?
many thanks, |
you are trying work out failed part of the power cct in the AC compresses control system
http://www.wikihow.com/Use-a-Multimeter |
sorry Dorsetsmith if this is obvious and I'm missing the point.
I know how to use the multimeter (thanks all the same for the link) but I'm not sure where I need to do the testing. I'll have another look at the diagrams but so far there's nothing getting to the compressor clutch but I've got a feed at the relay. So I'm guessing I need to find the wires leading to the pressure sensor and bell them out, find the wires leading to the temp sensor and bell them out and see which is open circuit.? |
