![]() | Home > Td5 > Rag top poles - too tall to go in the garage |
Rallymental Member Since: 17 Aug 2015 Location: The Garden of England Posts: 468 ![]() ![]() ![]() |
Maybe should have checked the new garage was up to the job first before building/buying/moving!!!!
![]() Solihull, 1948 - "If we paint the chassis, it will last for years" Solihull, 2015 - "If we paint the chassis............................. |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
Dig up the floor
cobra_mark Member Since: 17 Feb 2015 Location: West Yorks Posts: 213 ![]() ![]() ![]() |
Thanks it's times like this that I value the whit of my fellow man.
Tonneau cover then
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3665 ![]() ![]() ![]() |
shorter springs, lower profile tyres ? DEFENDER 90 TDCI XS,
One option agreed, or convert to county as that goes under fine.
Tonneau looks best option at present although the poles shortened and welded up would make the tight too small Exmor canvas fit finally.
![]() Click image to enlarge We are talking mm of clearance on the electric door switch so a re gig may clear it. |
A foot pump?
![]() Sorry couldn't resist ![]() Solihull, 1948 - "If we paint the chassis, it will last for years" Solihull, 2015 - "If we paint the chassis............................. |
Certainly no chance of any big wheels but she won't be out in the wet and snow anymore, worth the sacrifice and insurance drop.
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3820 ![]() ![]() |
What garage doors have you have?
I changed an up and over for barn doors. Slightly lower profile tires and shorter springs would help. How much gap do you need? Digging up the floor at the front could be an option? |
It's a roller door by Henderson, the switch is on the outside and give me 5 mm clearance on the cab. If it were moved I may get the rag in , can't dig up the floor expensive block paving.
The door is bust so may become a couple of opening doors so switch can go, measure up this weekend. ![]() |
JOHNT01670 Member Since: 24 Jun 2015 Location: CRAMLINGTON, Northumberland Posts: 190 ![]() ![]() ![]() |
Load it up with paving slabs? 2006 TD5
2002 Honda Transalp 650 1995 Yamaha Vmax 1200 2014 Nissan Juke (wifes) |
Getting a tonneau and will take 20mm out of the poles later this year, as long as I get the height level with the truck cab job done.
Skipped the tonneau idea lowered the poles, had the hood customised by LSR in Burnley. The result is......
![]() Click image to enlarge ![]() Click image to enlarge |
