Home > Td5 > Rag top poles - too tall to go in the garage
cobra_mark
United Kingdom 2000 Defender 90 300 Tdi SW Barolo Black
Quick question, has anyone every lowered the frame poles to the height of the cab roof on a TD5 pickup?
I say this as the pickup goes in my new garage but the frame has had to be removed as it is higher than the truck cab.
My first thought was to cut at the base of the pole and take enough to make the roof level then re-weld back and alter the canvas a little, any pointers welcome.
: Smile
Post #635536 4th Jul 2017 12:26pm
Rallymental
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Santorini Black
Maybe should have checked the new garage was up to the job first before building/buying/moving!!!! Rolling with laughter The definition of insanity is doing the same thing over and over again but expecting different results.
Solihull, 1948 - "If we paint the chassis, it will last for years"
Solihull, 2015 - "If we paint the chassis.............................
Post #635561 4th Jul 2017 4:05pm
ibexman
Dig up the floor
Post #635567 4th Jul 2017 4:47pm
cobra_mark
Thanks it's times like this that I value the whit of my fellow man.
Post #635593 4th Jul 2017 6:30pm
ibexman
Tonneau cover then Whistle
Post #635595 4th Jul 2017 6:34pm
LR90XS2011
shorter springs, lower profile tyres ? DEFENDER 90 TDCI XS,
Post #635610 4th Jul 2017 7:33pm
cobra_mark
One option agreed, or convert to county as that goes under fine.
Post #635611 4th Jul 2017 7:33pm
cobra_mark
Tonneau looks best option at present although the poles shortened and welded up would make the tight too small Exmor canvas fit finally.
We are talking mm of clearance on the electric door switch so a re gig may clear it.
Post #635613 4th Jul 2017 7:38pm
Rallymental
A foot pump?
Sorry couldn't resist Laughing The definition of insanity is doing the same thing over and over again but expecting different results.
Post #635615 4th Jul 2017 7:41pm
cobra_mark
Certainly no chance of any big wheels but she won't be out in the wet and snow anymore, worth the sacrifice and insurance drop.
Post #635616 4th Jul 2017 7:43pm
Stacey007
What garage doors have you have?
I changed an up and over for barn doors.
Slightly lower profile tires and shorter springs would help.
How much gap do you need?
Digging up the floor at the front could be an option?
Post #635618 4th Jul 2017 7:48pm
cobra_mark
It's a roller door by Henderson, the switch is on the outside and give me 5 mm clearance on the cab. If it were moved I may get the rag in , can't dig up the floor expensive block paving.
The door is bust so may become a couple of opening doors so switch can go, measure up this weekend.
Very Happy
Post #635620 4th Jul 2017 7:56pm
JOHNT01670
United Kingdom 2006 Defender 90 Td5 SW Zermatt Silver
Load it up with paving slabs? 2006 TD5
2002 Honda Transalp 650
1995 Yamaha Vmax 1200
2014 Nissan Juke (wifes)
Post #636007 6th Jul 2017 6:56pm
cobra_mark
Getting a tonneau and will take 20mm out of the poles later this year, as long as I get the height level with the truck cab job done.
Post #636023 6th Jul 2017 7:45pm
cobra_mark
Skipped the tonneau idea lowered the poles, had the hood customised by LSR in Burnley. The result is......
Post #692437 10th Mar 2018 3:59pm
