![]() | Home > Technical > non starter after clutch change |
Did all the earths get tightened correctly? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 618 ![]() ![]() |
Yup. All were labelled and connected.
I really took a lot of time over the whole job... as its a second car I could plod along and make it enjoyable rather than a chore. V8 90...WIP |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1827 ![]() ![]() ![]() |
Immobiliser?
Lock it, leave it to set, unlock and try again? GOOD LUCK |
It turns over, so not the immobiliser. But I did try that too anyway. V8 90...WIP
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
Perhaps if you give some details of the engine and which injection system you are using ? A 1989 V8 would be on carbs and wouldn't have a crank sensor. http://www.yorkshireoffroadclub.net/
Lol.
It's my 2.2 puma usw 2013. I had sort of assumed that was self explanatory because as you say, the v8 doesn't have a crank sensor. It really needs a plug in to get some live data but I don't have any trickery to do that with. I assume that somehow in unplugging stuff I have fractured a cable. I don't know if it's possible to check the crank sensor function without an oscilloscope or an engine diagnostic tool? V8 90...WIP |
check crank sensor, cam sensor
http://www.defender2.net/forum/topic48321....p;start=15 Last edited by dorsetsmith on 4th Jul 2017 2:48pm. Edited 1 time in total |
So an update. My LR dealer says he doesn't know when he can get a new crank sensor "they are on back order with Land rover" he says.
I checked the wiring for continuity to the plug, the three wires to the crank sensor are all good. The plug is clean and located well. Is the Engine light (the yellow engine picture on the dash) supposed to stay alight after the system self checks and only go out once the vehicle is started, or does it go out straight away once the self checks are done? V8 90...WIP |
Fixed. fractured accelerator cable shorting to earth V8 90...WIP
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6319 ![]() ![]() ![]() |
well done
![]() was it fractured through movement or did it get sqweeshed by the engine? ![]() happy caravanning ![]() |
one to add to list good news
Clearly been previously fiddled with.. No outer protection and rubbing on the brake pedal box bolt. I assume I pulled it whilst fitting trim and clutch V8 90...WIP |
