Home > Td5 > Clutchfix HD1 with DMF thoughts please?
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
http://tmdtuning.com/shop/clutchfix-hd1-de...thflywheel
Hi I need a new clutch in my td5 90 it has larger intercooler, Griffen sports exhaust and egr blank. At some point will get remapped aswell. What are your thoughts on fitting the clutch and dmf in the link above? Will it handle power upgrade well?
Thanks in advance
Andy Thumbs Up
Post #635283 3rd Jul 2017 11:29am
bankz5152
For one it will make your clutch about 25% heavier. My 110 is around 190bhp/450nm torque and the standard clutch is dealing with everything fine, as far as I can tell anyway!
Post #635292 3rd Jul 2017 12:12pm
Oakseywick
So what should I go for?
Post #635294 3rd Jul 2017 12:23pm
bankz5152
Standard Valeo kit should do the job.
http://www.ebay.co.uk/itm/landrover-td5-cl...2309906799
Shop around you may find it cheaper, just make sure its Valeo
Post #635296 3rd Jul 2017 12:26pm
JOW240725
I'd speak to Ben Williams at Clutchfix, see what he recommends? James
Instagram @suffolk_rovers
Post #635310 3rd Jul 2017 1:08pm
Oakseywick
Hi James I did speak with him and he recommended there heavy duty clutch and solid mass flywheel kit which was around £700. After reading on here about effects of solid mass flywheels I am being put of a SMF and would prefer the smother dmf, not sure if the Clutchfix HD1 clutch and Valeo dmf is a better option or just go for complete valeo kit. Confused
Post #635313 3rd Jul 2017 1:14pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I will be replacing my clutch with a clutchfix hd1 and dmf shortly have driven a few with this setup and it's superb mines running circa 180bhp
So yes definateley clutchfix for me 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #635314 3rd Jul 2017 1:17pm
pj2106
Just buy direct from clutchfix!! 2008 110 2.4 XS Utility (Hagrid)
Post #635316 3rd Jul 2017 1:18pm
JOW240725
That is quite a cost difference! Hopefully, some people might be able to provide you with some more educated advice! James
Post #635317 3rd Jul 2017 1:19pm
Oakseywick
Did you find the HD1 dmf setup heavier than the standard as banks said?
Post #635320 3rd Jul 2017 1:21pm
pj2106
Very minimal difference
One friend has a red booster fitted so there was no difference from std
I would stick with the dmf over a solid fly tbh they can be noisy and rattle.
Speak to Ben Williams and mention Land Rover legends on Facebook and I'm sure he will sort you a bit of discount as he has for me 😊👍😊👍 2008 110 2.4 XS Utility (Hagrid)
Post #635365 3rd Jul 2017 5:47pm
