Home > Maintenance & Modifications > Rear LED lights
stephan123
Rear LED lights
Hi,
Anybody know where I can buy some SVX style rear LED lights? Land Rover are quoting more than £500!
Currently have Wipac LEDs but feel like they look quite cheap and glitzy.
Any help would be much appreciated!
Stephan
Post #635099 2nd Jul 2017 2:06pm
mk1collector
Post #635100 2nd Jul 2017 2:12pm
ericvv
Post #635103 2nd Jul 2017 2:54pm
Mo Murphy
Mud.UK.
50 Shades of Pennine Grey
Post #635106 2nd Jul 2017 3:19pm
stephan123
Thanks guys! Looks like Mobile Centre is the best option for peace of mind!
Post #635118 2nd Jul 2017 4:49pm
ericvv
Probably right. And when you compare the prices and you see that Mobilecentre is a price everything that is needed included, but with Mud you still have to buy the plinth for each lamp separately at 9.60£ a piece, the first is going to work out better too. I have bought things from both companies, always good experiences, but Mobilecentre also are a site sponsor on here.
Eric
P.S. I suggested that you would read that copied thread carefully, just be aware that you may have to drill new holes in your rear panels for these 95mm plinths. Not exactly plug 'n play compatible if you have standard lights now. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #635121 2nd Jul 2017 5:07pm
zsd-puma
Post #635126 2nd Jul 2017 5:41pm
mk1collector
Eric
You don't have to drill holes in the rear panel! Just drill holes in the plinth to match your existing rear panel clips. Ray
My build thread
Post #635127 2nd Jul 2017 5:47pm
ericvv
Post #635129 2nd Jul 2017 6:07pm
Vitesse
i purchased mine from Dun Bri Group. Genuine Perei make. Really good price. Found some plinths on eBay (correct ones) and then a bit of wiring and sourced connectors ,as luckily this is my line of work. All in about £210
But as recommended on here by others, the kits supplied ready to go are also good and will save you money Thumbs Up 2015 90 XS Santorini Black
Post #635157 2nd Jul 2017 7:53pm
stephan123
Is it possible to screw the rear lights from the back? If I'm going to spend several £100s on lights I want to make sure they are at least thief proof!
Post #636422 8th Jul 2017 6:11pm
zsd-puma
I'm not really sure how you'd do it. You could just buy some security screws and screw them in from the front as usual. Obiously all security screws have tools readily availiable to undo them, but it makes it a bit more difficult for the oportunist in a car park.
Post #636523 9th Jul 2017 11:39am
Stacey007
Alloy plinths and lights from CSI parts, Great stuff I like them (still need to change the fog and reverse light plinth)
Much brighter and imho safer than the OEM ones.
Post #636618 9th Jul 2017 8:21pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
the csi plinths do not fit the oem perie light units.
Post #636763 10th Jul 2017 3:30pm
mk1collector
I've just had an email from Thomas at CSI saying he's getting some of the plinths machined up next week to fit perei lights after I gave him all the measurements. Thumbs Up Ray
My build thread
Post #636764 10th Jul 2017 3:44pm
