Home > Maintenance & Modifications > Rear LED lights
Page 2 of 2 <12
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
happy days, i originally had a set from him but had to send them back due to not fitting.
Post #636765 10th Jul 2017 3:47pm
mk1collector
Just edited my post after re-reading his email, he's having them machined next week Thumbs Up Ray
My build thread
Post #636766 10th Jul 2017 3:48pm
stephan123
Thank you for all of your helpful suggestions. In the end I bought the LEDs and connectors myself (thanks to Martin). Fitting was very straightforward.
Only issue is that the OEM 95mm plinths I bought differ from the factory-fitted fog/reverse plinths (the ones fitted at the factory are the same diameter but more shallow) hence the new fog and reverse LEDs are protruding slightly. Will replace with OEM 95 mm plinths when I figure out how to remove the existing ones! (think they must be removed from the back). Anyway here is a before and after for your viewing pleasure Very Happy
Post #659138 23rd Oct 2017 11:22am
Page 2 of 2 <12
