![]() | Home > Technical > Any ideas? |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
mounts for steering box, engine, gearbox, tbox?
ooh - one other thought, i had a similar knock years ago and it was a couple of loose wheel bolts, funnily enough just after a service! BM52 |
I could be early sign of a cv about to let go but other than that I would have said radius arm bushes.
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
i don't do much tech speak but here goes, i did get a knock similare to that and i needed the pre load resetting, three times, in the end the chimps did a wheel bearing as well on that corner plus the swivel seal, it really showed when the mot guy had in on the lift and raised of the wheels and he could get the swivel seal opening at least 1 mm with him rocking the wheel in and out with his body weight.
it seamed to get pulled on its slack then jump back as the weight shifted and the slack allowed the knock. if the swivel isnt leaking its not that. HTH mark |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2450 ![]() ![]() ![]() |
Did u check upper bushes from the upper link assembly and the bolts from the bracket attached to the chassis? Puma 110" SW
Thanks Chaps. Will check all those on monday when I can get back on the ramp
Frustration took over. Couldnt leave it so tried again with a trolley jack.
swivel ok, no play, not leaking. wheel bearings ok. steering mounts all ok. checked radius arm bushes again, all fine. last thing i can think of which didnt strike me at the time is front anti roll bar mounts. |
Rear anti roll bar on fuel tank guard causes a similar issue
![]() Click image to enlarge 130's have feeling's as well you know ![]() |
Cheers Andrew. Odd thing is that the bushes on the anti roll bar mounts look fine though I didnt stick a bar in them to really check properly. I guess there is a chance that the noise is resonating from the rear. Am very frustrated with this, will have to wait til next week now.
In my case it wasn't the bushes it was the anti roll bar touching/catching the tank guard whilst cornering. 130's have feeling's as well you know
SJM Member Since: 09 Dec 2007 Location: Kent Posts: 237 ![]() ![]() |
Just a thought on this (as I'm now getting the same problem on mine), but could this be caused by added weight on the front of the truck? For example, I have the soft A-bar and a steering guard added - what about yours Mike? And others that have had this problem?
Another thought, and hopefully not as stupid as it might sound... ![]() ![]() '11 Defender 110XS Utility SW '07 Discovery 3 HSE '58 Porsche 356A (not good off road) '59 Lambretta (not good on or off road!) |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5068 ![]() ![]() ![]() |
I have/had an abar,winch,spots, steering guard etc on the front no noise Mike
Long shot Mike but re-torque the axle tie rods that run fore and aft came loose on mine took ages to find
![]() 110 HCPU Tipper |
No it's not to do with weight. I have a winch bumper and winch and the tubular LR steering guard rather than the snowplough one, but I also have stuffer springs too.
It sounds like something is slipping one way then the other over a very short distance, but having been all over it with a pry bar and checked all the nuts, bushes etc I just cant find anything. My dealer visit has been put back until next week because they didnt have the side replacement ally trim painted up so its now not going into til next monday where they will have it "for a few days". joy of joys. |
cheers Willy, will put that down on the list for them to look at. |
