Home > Technical > Any ideas?
BigMike
Any ideas?
Whenever I go round sharp bends or roundabouts, as the vehciles weight shifts left there is a pronounced knock. when the wheels straigtend again coming off the roundabout etc, there is a corresponding knock, slightly quieter.
So far I have checked
shock and shock mount
turret
spring
drag link ball joints (drag link is new-ish sumo)
track rod (sumo and fairly new)
steering was laser aligned last week and it hasnt been offroad since to knock it out.
radius arm bushes are fine
the knock only happens on weight transfer when sharp cornering. It's going to the dealer next week to have new rear side windows as the current ones leak badly, and whilst I will ask them to look at this, they are likely to say "ah you have aftermarket shocks and springs, drag and track rod, trailing arms etc so nothing to do with us guv'nor"
Any ideas anyone?
Post #63310 11th Mar 2011 5:54pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
mounts for steering box, engine, gearbox, tbox?
ooh - one other thought, i had a similar knock years ago and it was a couple of loose wheel bolts, funnily enough just after a service! BM52
Post #63322 11th Mar 2011 7:18pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
I could be early sign of a cv about to let go but other than that I would have said radius arm bushes.
Post #63323 11th Mar 2011 7:27pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
i don't do much tech speak but here goes, i did get a knock similare to that and i needed the pre load resetting, three times, in the end the chimps did a wheel bearing as well on that corner plus the swivel seal, it really showed when the mot guy had in on the lift and raised of the wheels and he could get the swivel seal opening at least 1 mm with him rocking the wheel in and out with his body weight.
it seamed to get pulled on its slack then jump back as the weight shifted and the slack allowed the knock.
if the swivel isnt leaking its not that.
HTH
mark
Post #63339 11th Mar 2011 8:53pm
MK
Did u check upper bushes from the upper link assembly and the bolts from the bracket attached to the chassis? Puma 110" SW
Post #63349 11th Mar 2011 10:21pm
BigMike
Thanks Chaps. Will check all those on monday when I can get back on the ramp
Post #63367 11th Mar 2011 11:53pm
BigMike
Frustration took over. Couldnt leave it so tried again with a trolley jack.
swivel ok, no play, not leaking. wheel bearings ok. steering mounts all ok. checked radius arm bushes again, all fine. last thing i can think of which didnt strike me at the time is front anti roll bar mounts.
Post #63464 12th Mar 2011 8:10pm
AndrewS
Rear anti roll bar on fuel tank guard causes a similar issue
 130's have feeling's as well you know Smile
Post #63469 12th Mar 2011 8:56pm
BigMike
Cheers Andrew. Odd thing is that the bushes on the anti roll bar mounts look fine though I didnt stick a bar in them to really check properly. I guess there is a chance that the noise is resonating from the rear. Am very frustrated with this, will have to wait til next week now.
Post #63471 12th Mar 2011 9:02pm
AndrewS
In my case it wasn't the bushes it was the anti roll bar touching/catching the tank guard whilst cornering. 130's have feeling's as well you know Smile
Post #63473 12th Mar 2011 9:19pm
SJM
Just a thought on this (as I'm now getting the same problem on mine), but could this be caused by added weight on the front of the truck? For example, I have the soft A-bar and a steering guard added - what about yours Mike? And others that have had this problem?
Another thought, and hopefully not as stupid as it might sound... Whistle , but....does this really make any fundamental difference to the integrity/ safety of the truck? Obviously it is not meant to happen, but could it be one of those things that can happen but doesn't matter? I'm not in the least bit mechanically minded so please be kind with your answers!! Thumbs Up Simon
'11 Defender 110XS Utility SW
'07 Discovery 3 HSE
'58 Porsche 356A (not good off road)
'59 Lambretta (not good on or off road!)
Post #63935 16th Mar 2011 3:29pm
mse
I have/had an abar,winch,spots, steering guard etc on the front no noise Mike
Post #63944 16th Mar 2011 4:05pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Long shot Mike but re-torque the axle tie rods that run fore and aft came loose on mine took ages to find Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #63988 16th Mar 2011 7:34pm
BigMike
No it's not to do with weight. I have a winch bumper and winch and the tubular LR steering guard rather than the snowplough one, but I also have stuffer springs too.
It sounds like something is slipping one way then the other over a very short distance, but having been all over it with a pry bar and checked all the nuts, bushes etc I just cant find anything. My dealer visit has been put back until next week because they didnt have the side replacement ally trim painted up so its now not going into til next monday where they will have it "for a few days". joy of joys.
Post #63989 16th Mar 2011 7:35pm
BigMike
cheers Willy, will put that down on the list for them to look at.
Post #63990 16th Mar 2011 7:39pm
