Home > Maintenance & Modifications > Megga Prop (front)
Page 1 of 3 123>
AndrewS
Megga Prop (front)
Fitted one of these today to J-Lo
90% of the vibration issues have now gone Thumbs Up
I know that the props shown are not sat the same way round Confused
 130's have feeling's as well you know Smile
Post #63337 11th Mar 2011 8:47pm
mick
Is it the prop that cured the vibrations or the dealer what have they done Thumbs Up
Post #63340 11th Mar 2011 8:53pm
AndrewS
All the dealer has done so far is a 24k service, not touched the 'issues' yet, however now there are less issues. Thumbs Up 130's have feeling's as well you know Smile
Post #63341 11th Mar 2011 8:57pm
mick
Can you get the props balanced .
Thumbs Up any spring news Whistle
Post #63343 11th Mar 2011 9:06pm
AndrewS
Waiting to be given purchase history then I will know whats what Thumbs Up 130's have feeling's as well you know Smile
Post #63344 11th Mar 2011 9:11pm
mick
Thumbs Up
Post #63345 11th Mar 2011 9:12pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
I thought that this kind of props were only usefull if we had a lifted supension...
What is the advantage of having one of these ? ... besides ending the vibrations ? Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #63443 12th Mar 2011 6:25pm
AndrewS
I have a lift Thumbs Up 130's have feeling's as well you know Smile
Post #63445 12th Mar 2011 6:38pm
lrmaniac
oops ! Whistle did not know ! I was really curious if there was any other benefit of fitting one with standard suspension ... Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #63449 12th Mar 2011 7:01pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Hi Andrews what make prop is it and what lift do you have bought the equipe one for my truck cost a fortune but it certainly works
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #63539 13th Mar 2011 2:13pm
^^^ I agree, i've got an equippe one here (off of my old 30Tdi), going to cut & shut it to fit the project90-3 (Td5).
It made the world of difference to vibrations, and is a well made bit of kit.
Post #63569 13th Mar 2011 6:12pm
AndrewS
I think its a "Megga" prop from Italy, Got it from devon 4x4 at a cost of about £400 130's have feeling's as well you know Smile
Post #63585 13th Mar 2011 7:57pm
big steve
Sounds to me like the new Bailey Morris prop the joint is from Italy the same as equipes
Nice bit of kit
Regards steve 2015 2.2 tdci hardtop xs
Post #63605 13th Mar 2011 8:42pm
Is the DC joint on your new prop fully greasable and servicable? I am sure that the UJs are greasable, but is there a nipple for the centre bearing?
The DC joint on the Disco 2 is reckoned to be a notorious weak spot and if it fails catastophically can do £££ of damage to the car. I rebuilt a spare shaft with components from the States to provice larger UJs and full serviceability ready to fit to my Disco 2 but actually haven't yet had to fit it, and my original has done 200k miles. My Disco is a TD5 however, and I think the root cause of the reported propshaft failures is that on the V8 version the grease bakes out of the joints. I still think it was barmy to supply propshafts with "sealed for life" UJs though (but at the same time LR was building cars with no centre diff, so clearly the firm was going through a bad spell).
On a Puma the propshaft is that bit nearer the exhaust (and if you haven't removed it) the cat, and I wonder if there may be a similar problem.
Post #63645 14th Mar 2011 9:09am
MK
I have a toyota high angle CV jointed and it is a sweat. Fully greasable including the "hidden" central bearing.
Make sure you get a proper angle alignment between the diff flange and front end of the propshaft (ie. 0-3º max). Puma 110" SW
Post #63662 14th Mar 2011 11:13am
Page 1 of 3 123>
