![]() | Home > Td5 > 110 CSW Rear Seat Configuration Question? |
Triple7 Member Since: 30 Aug 2015 Location: Down South Posts: 70 ![]() ![]() ![]() |
I'm looking at getting a 110 TD5 CSW, so flicking through a few adverts and found the below
https://www.ebay.co.uk/itm/263038890914 The middle row seating has 3 separate high back seats, was this an option from new or retro fitted (like an exmoor upgrade)? Just never seen this setup before (not that i've been looking long) |
Thanks for the info Retroanaconda
![]() I like the look of it |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 ![]() ![]() ![]() |
You can see the Exmoor trim label in the pictures on the second row seats.
Patrick |
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 872 ![]() ![]() ![]() |
... and I can thoroughly recommend 'em, too. My TD5 110 was originally an 11-seater (2 seats + 3 seats + 2 x 3-seater side benches), by fitting them I lost 2 seats at the back (3-seater benches were longer than 2-seater benches or single seats).
But oh so much more comfortable for second-row passengers, able to recline rather than be forced to sit bolt upright with little back support. Peter |
Thanks all
Definitely sounds like a good upgrade. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 ![]() ![]() |
Im planning on doing the same but with the "Classic" high backs, either way an improvment over the standard!
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
I like the idea of the Exmore three middle row seats for flexibility of dropping the middle seat or removing all together. However I've never found out how you get the 3-point seat belt on the middle seat which would be needed in a Puma. As I understand the older models have just a lap belt on the middle seat. Be interested to learn, if any one knows and has photos? TIA James
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 623 ![]() ![]() ![]() |
I've got the Exmoor Trim seats, with highbacks on the outside and a lowback in the middle so I can use the rear view mirror. Only has a lap belt in the middle. I was looking for alternatives that included a middle seat three point belt. I was told that P38 seats could be made to fit, but haven't investigated further. I'd be interested to see what you come up with.
