Home > Td5 > 110 CSW Rear Seat Configuration Question?
Triple7
United Kingdom 2004 Defender 90 Td5 SW Oslo Blue
I'm looking at getting a 110 TD5 CSW, so flicking through a few adverts and found the below
https://www.ebay.co.uk/itm/263038890914
The middle row seating has 3 separate high back seats, was this an option from new or retro fitted (like an exmoor upgrade)?
Just never seen this setup before (not that i've been looking long)
Post #633286 24th Jun 2017 3:02pm
Retroanaconda
Td5 vehicles had low back seats, those will be an aftermarket addition. Exmoor Trim do them as you mention.
Factory fitted high-back seats came in with Tdci in 2007, they can be fitted to earlier vehicles but it requires a bit of cutting about and modification.
Post #633291 24th Jun 2017 3:48pm
Triple7
Thanks for the info Retroanaconda Thumbs Up
I like the look of it
Post #633293 24th Jun 2017 3:53pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
You can see the Exmoor trim label in the pictures on the second row seats.
Patrick
Post #633506 25th Jun 2017 7:39pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
... and I can thoroughly recommend 'em, too. My TD5 110 was originally an 11-seater (2 seats + 3 seats + 2 x 3-seater side benches), by fitting them I lost 2 seats at the back (3-seater benches were longer than 2-seater benches or single seats).
But oh so much more comfortable for second-row passengers, able to recline rather than be forced to sit bolt upright with little back support.
Peter
Post #634343 29th Jun 2017 10:15am
Triple7
Thanks all
Definitely sounds like a good upgrade.
Post #634366 29th Jun 2017 11:47am
bankz5152
Im planning on doing the same but with the "Classic" high backs, either way an improvment over the standard!
Post #634371 29th Jun 2017 12:08pm
JOW240725
I like the idea of the Exmore three middle row seats for flexibility of dropping the middle seat or removing all together. However I've never found out how you get the 3-point seat belt on the middle seat which would be needed in a Puma. As I understand the older models have just a lap belt on the middle seat. Be interested to learn, if any one knows and has photos? TIA James
Instagram @suffolk_rovers
Post #634372 29th Jun 2017 12:11pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I've got the Exmoor Trim seats, with highbacks on the outside and a lowback in the middle so I can use the rear view mirror. Only has a lap belt in the middle. I was looking for alternatives that included a middle seat three point belt. I was told that P38 seats could be made to fit, but haven't investigated further. I'd be interested to see what you come up with.
Post #634380 29th Jun 2017 1:07pm
