Home > V8 > v8 slow return to idle
Nige71
United Kingdom 1997 Defender 110 V8 Petrol CSW Nato Green
Hello All
Please any info 1997 v8 crabs seems to be very slow return to idle when revved up .
Thanks Nige
Post #633780 26th Jun 2017 8:28pm
Is this from cold or when up to temperature?
Post #633794 26th Jun 2017 8:55pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Have you lubricated the linkages and cable lately? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #633795 26th Jun 2017 8:57pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Dash pot oil level ok? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #633796 26th Jun 2017 9:02pm
Nige71
seems same hot or cold
haven't checked cable lubed up
dash pot oil ok
Thanks for info
Post #633815 27th Jun 2017 5:54am
Romadog
Adding to Mash...are the pivots/linkages clean and not gunked up?
Also return springs weak?
Disconnect throttle cable from engine and see if issue occurs then you know if it an issue at the carb or throttle pedaland cable.
Thumbs Up
Post #633905 27th Jun 2017 5:14pm
Nige71
thanks will try linkage .
Post #633938 27th Jun 2017 8:13pm
Nige71
Have checked the return spring and is very strong on the return , the cable is very loose and lubed ?
Post #635033 2nd Jul 2017 7:52am
oneten110
if you have SU carbs it might be the poppet valves on the butterfly are sticking. Options include, replacing the butterflies like for like, soldering the valves shut, or throwing the butterflies in a bin and fitting plain butterflies. That way you need never worry about the problem again and you get rid of a restriction in the airflow
Post #646284 25th Aug 2017 3:30pm
