Home > Maintenance & Modifications > Have avoided a RAI until ....
familymad
Funnily enough but my air filter was showing clear signs of filling with dust after two days pottering behind another vehicle on the plains last weekend. Not my every day drive I admit but our overland plans have me toying with either the Entreq RAI or a Safari with added Nugget bits
Either
http://www.entreq.de/fahrzeugtechnik/ansau...rchel.html
Or standard Safari snorkel with
http://www.nuggetstuff.com/product/defender-puma-sealed-airbox/
and
http://www.nuggetstuff.com/product/nugget-...e-adaptor/
Has anyone fitted an Entreq Airflow II kit? Not sure if that waterproofs the set up? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #633273 24th Jun 2017 12:39pm
leeds
Post #633280 24th Jun 2017 1:24pm
camelman
I've fitted the Southdown which is fully sealed and comes in at £159.
http://www.southdown4x4.co.uk/Snorkel%20De...norkel.htm
Also fits with or without a roll cage
Post #633282 24th Jun 2017 1:30pm
ericvv
Re: Have avoided a RAI until ....
The Entreq RAI is a real snorkel, so fully waterproof. The Entreq Airflow Kit II also is fully waterproof, unlike the standard Defender air intake part PHD500950. So a combination of the Entreq snorkel plus the Airflow Kit II should get you a fully waterproof system. Not sure if Olaf would send over the Airflow Kit II for self-install. The price for this part on his website includes the installation cost by him at his workshop, and there is no shipping option. No doubt this is to be sure that the installation is fully waterproof. For me this is no problem, I won't install the snorkel, but will let Olaf install this summer the Airflow Kit II. That is the last of three Entreq parts I still need to fully optimize the airflow intake and air supply to the engine. The other two, Entreq intercooler and stainless intercooler pipes are already installed on my truck.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #633300 24th Jun 2017 4:35pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
You will probably find this will fit and is a proper snorkel. Installed one on my TD5 and I believe should fit the Puma but you would need to check the entry in to your air box.
https://www.safari4x4.com.au/products/land...ries#parts
It is a snorkel not a RAI and would save having to buy two items from different manufacturers to get the same result.
Been discussed before
http://www.defender2.net/forum/topic31039.html 2007 TD5 90 Hard Top
Post #633345 24th Jun 2017 8:04pm
I can highly recommended the Nakatanenga snorkel, Brendan's second link. Excellent quality, replaces the constricted original intake duct, and enhances performance. Expensive, but you get what you pay for.
It is amazing how much crud collects in the centrifugal precleaner in normal use, better there where you can tip it out than in the air filter.
Post #633347 24th Jun 2017 8:24pm
familymad
Thanks,
The second Naka option shows coming out of thr wing top. Is that the same on RHD? Does it come with the blanking plate for the original intake? Also can it be waterproofed well? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #633408 25th Jun 2017 7:56am
Yes, same on RHD (mine is RHD). All the Nak bits are fully sealed, so the only things left to seal are the airbox drain holes. It's a very impressive kit.
It's also available in 2 versions, one for roll-cage-fitted vehicles, and one for those without.
You'll have to provide your own blanking plate, I used an ex-military plate bought from ebay (used on the waterproof conversion kits).
Post #633586 25th Jun 2017 10:33pm
charcoal
United Kingdom 2005 Defender 110 Td5 HT Bonatti Grey
I like the look of that Blackwolf. Was looking for a wing top one for my Land Rover but thought Mantec were the only company that made them. How much was it if you don't mind me asking? 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold
1995 Land Rover Defender 110 V8 Station Wagon ~ Sold Sad
1985 Land Rover 110 ex mod project Tithonus ~ Sold Sad
Post #633595 25th Jun 2017 11:32pm
You may want to sit down before scrolling down...
£360 all up inc. delivery. But absolutely worth every penny, especially when you consider that you don't just get the external bits but also the equivalent of a "Nugget duct" as well. Price up a Safari Snorkel or similar (which is less well engineered) plus an ND and you'll be in the same range I'll wager.
It is quite simply the best snorkel on the market today.
Post #633598 26th Jun 2017 12:12am
Post #633599 26th Jun 2017 12:33am
charcoal
Oof. Then again the Mantec one cost about £300 so it's not that much more. Will look into that when I get my next Defender then. 1999 Land Rover Defender 110 td5 station wagon
Post #633600 26th Jun 2017 12:55am
familymad
Mind made up then. That looks great.
Brendan,
Do you supply?
Thanks 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #633709 26th Jun 2017 3:46pm
leeds
Yes we supply.
If it is Nakatanenga we can supply.
Currently out of stock of them.
IIRC there should be some on the pallets due in next week.
Brendan
Post #633717 26th Jun 2017 4:46pm
Stacey007
'Looks' wise the southdown looks much better with out the pipe bent along the bonnet?
Assuming these are both sealed units, do the same thing?, the price is a huge difference.
Post #633738 26th Jun 2017 6:44pm
