Home > Maintenance & Modifications > Scary steering issue
JamesF
United Kingdom 1989 Defender 90 2.5 TD HT Baltic Blue
Really scary steering issue
Hi guys after advice again. I drove home from work today and as I went over a porly matained rutted stretch of road my steering started vibarting really baddly and did not stop until I came to a halt. It really shook me up (no pun intended)
I checked my wheel nuts and the steering gear.. nothing seems loose or amiss.
Can anyone suggest what it might be? possibly the steering damper?
As always thanks for any advice
Post #632912 22nd Jun 2017 3:53pm
Could be steering damper, but if it's that bad then it's more likely to be the pre-load on the swivels. Darren
Post #632917 22nd Jun 2017 4:02pm
bear100
steering damper i would say 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #632918 22nd Jun 2017 4:02pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
+1 for Pre load on swivels. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #632921 22nd Jun 2017 4:31pm
swaini
United Arab Emirates 1997 Defender 90 V8 Petrol ST Auto Barolo Black
hi all,
i just bought a td5 that was unused for 2 years apart from the occasional startup. my first drive in her is pretty close to what you are describing. steering damper was shot, all the bushes in the front suspension had disintegrated along with steering rod and stabiliser.
she back to new now.
swaini
Post #632932 22nd Jun 2017 5:28pm
P@ul
United Kingdom 1996 Defender 90 300 Tdi HT Epsom Green
I've had that problem and it was the preload on the swivels.
Paul
Post #632934 22nd Jun 2017 5:34pm
Swivels.
Quite scary, isn't it?
Post #632945 22nd Jun 2017 5:57pm
JamesF
Thanks guys.. forgive my ignorance but what is a pre load on the swivels?
Post #632947 22nd Jun 2017 6:00pm
dorsetsmith
Post #632958 22nd Jun 2017 7:00pm
roel
It is the preload on the swivel bearings. A steering damper helps but is not the solution off the problem. Roel
2003 90 Td5 (2009-now)
Post #633003 22nd Jun 2017 9:01pm
JamesF
Thanks everyone again for all the advice. I am going to change the steering damper anyway as it looks very tired. I looked at the swivel housing sets and they are reasonable but I imagine that my garage will take quite a while to change them so expecting it to be expensive.
Cheers again
Post #633113 23rd Jun 2017 12:05pm
agentmulder
Kuwait
Did mine in the driveway - and I'm hardly a mechanic! I'm sure we can help you through it, my guess, taking it easy is two days, although there will be others that suggest only half, with a cup of tea. Solved the bowel problem, working on the consonants...
Post #633231 24th Jun 2017 1:42am
sako243
Swivels are worth a check but also check the panhard rod. 99 times out of a hundred there's play in the bushes. If you can see any then it's waaaay too much.
Even if you can shift it with a bar it's too much. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #633283 24th Jun 2017 1:34pm
