Dreamweapon
MAP, MAF seal and Brake fitting kit part numbers | |
I'm planning to give the MAP and MAF a blast with some electronic cleaner, since my 2008 110 has over 200k on the clock, I thought that it may be an idea to replace the o ring and seal as recommended in the workshop manual. In MICROCAT, I can't find the parts numbers for these seals, does anybody have the JLR or Ford PNs for these components?
Also, rear brakes are due for a pad change and I would like to change the pins and springs over, the landroverworkshop.com Microcat (thanks to whoever put up that site) only shows STC8754 which I think is only 90 and Disco.
What is the correct rear brake fitting kit part number for a 2008 110 van with ABS?
Thanks in advance ..
22nd Jun 2017 1:01pm |
