Home > Technical > Rough cold idle - what's the diagnosis?
Page 3 of 4 <1234>
Naks
yikes, the problem is getting worse!
this morning on startup, there was a large white cloud of smoke, which didn't go away for at least 5 min, even while driving.
I ran a scan and there were a lot of faults about injectors:
and also these:
Now my battery is dying, could a low battery cause this? --
Post #632574 21st Jun 2017 6:41am
dgardel
Italy
Sorry Naks but I can't see the photos.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #632691 21st Jun 2017 6:22pm
dgardel
Italy
Normally not, the Defender isn't "battery sensible" like the D3 or D4 go or no go..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #632693 21st Jun 2017 6:25pm
Naks
Dammit, I was hoping it was just the battery. Sad
In any case, the battery is 7 years old and is busy dying, so replacing it won't hurt. I will report back once I get the car back from the auto electrician. --
Post #632814 22nd Jun 2017 9:51am
Naks
update: replacing the battery had no effect on the smoky startup
waiting for a slot at my indie to have the VCV replaced. --
Post #633079 23rd Jun 2017 8:03am
jst
did you solve this?
my 90, 2.4 69k miles has same symptons as original post under same conditions.
had do i check VCV and Fuel pressure rail relief valve??
MAP and MAF are good. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #649969 12th Sep 2017 8:45pm
Naks
Not yet James, landy is in the shop this week for the glow plugs & injectors to be removed & tested while I'm going to Singapore.
I will report back once the tests have been done. --
Post #649993 13th Sep 2017 3:53am
jst
ok, so its obviously not a show stopper from using it then considering the time. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #649996 13th Sep 2017 4:53am
Naks
James, that is correct, I have been driving it like this since June.
BUT, if the injectors are fubar and leak too much diesel, you run the risk of burning holes through the pistons. There is also the risk of the engine oil being diluted too much, which can cause the crank to snap.
I have avoided doing any long distance driving (anything over 40km) just in case. --
Post #650012 13th Sep 2017 7:43am
jst
she is not burning excessive diesel or loosing it and engine oil is all good.
would that indicate more likely to be the PRRV? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #650083 13th Sep 2017 1:10pm
Naks
Just heard back from my indie: injectors were tested and are fine.
Glow plugs are also fine.
Not sure where to go from here. --
Post #651260 19th Sep 2017 11:32am
jst
EGR? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #651283 19th Sep 2017 1:15pm
Naks
no, the EGR is shut via the remap. --
Post #651422 20th Sep 2017 5:28am
DavinaTree
United Kingdom 2011 Defender 110 Puma 2.4 USW Alaska White
im having somewhat similar issues to those in this thread so im watching this too. loss of power and low down torque- occasional pulsing or lumpy idle, checked a lot of things and autologiced etc etc, wrote it off as a minor gremlin on mechanics advice but I definitiely think im going to change the VCV - does anyone who has done it think they could write a tutorial or does anyone have a link to a video or summat? TIA
Merry Christmas n all that..
Post #808023 29th Dec 2019 9:35pm
skidrov
Australia 2010 Defender 110 Puma 2.4 SW Fuji White
Just did mine, the most useful post I found was:
https://www.defender2.net/forum/post743584.html#743584
The only thing I'd add is to make sure you get a good quality VCV - there are suggestions in the linked thread. As it happens, I got mine from BAS, which worked out well for me. Finally, most of the linked thread is around the 2.4, can't comment on relevance to the 2.2.
Post #808043 30th Dec 2019 7:13am
Page 3 of 4 <1234>
