Home > Technical > Rough cold idle - what's the diagnosis?
Page 2 of 4 <1234>
Bluest
That looks rock solid to me. Mine was up and down, nearly​ stalling. 2007 110 TDCi Station Wagon XS
Post #624784 17th May 2017 8:06am
Naks
yeah, unfortunately by the time I got to my phone, it had stopped doing it.
Will monitor over the next few days, this is the first time ever that it has done something like this.
I estimate that the revs were going up by about 200-500rpm --
Post #624786 17th May 2017 8:12am
Clean the MAP and MAF sensors as a good start, free to do more or less as well.
Mine was gunked up, especially the MAP and had a significant increase in performance and quality of stable smooth idle. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #624808 17th May 2017 10:36am
Naks
Shot Steve, will do that Thumbs Up
I've actually need quite lazy, I used to inspect/clean these every month, but haven't for a while. Whistle --
Post #624841 17th May 2017 12:43pm
Mine wasn't cleaned for years. Embarassed
Just didn't know anything much about it until recently with the wealth of knowledge here.
Worth a go anyway. Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #624842 17th May 2017 12:50pm
Naks
captured some data yesterday at idle (hot) and 2000rpm. Do these look normal?
Post #625046 18th May 2017 8:24am
Naks
Finally got around to doing some checks on the car today.
Both the MAP and MAF were clean, no real gunk to speak of on either.
So I'll put it down to some dirt pickup due to having run the previous tank very low. I will make a note to tell my indie to drop & clean the tank and the next oil change in August, --
Post #625879 21st May 2017 8:41pm
Naks
damn, it did it again this morning, ambient was 14C.
I can rule out the diesel as this was a different tank from a different petrol station.
what now? Question --
Post #631046 13th Jun 2017 12:01pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Change your VCV valve!
I had exactly the same symptoms over the winter.
You need to read live data when it's cold to get the fluctuations a bad VCV would give,
It should be all over the place on cold start up, getting better as it warms up. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #631053 13th Jun 2017 12:21pm
As it's persistent, it could well be the VCV as suggested above.
None the less, it was worth cleaning the MAF & MAP sensors. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #631088 13th Jun 2017 3:07pm
Naks
yep, it did it again this morning.
Skip to 29s in the video:
Post #631254 14th Jun 2017 8:33am
Jerry
2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
could it be the grade of diesel - see this thread?
http://www.defender2.net/forum/topic55077.html
Post #631288 14th Jun 2017 11:08am
Naks
I thought it may have been, but this is a new tank from a different brand.
previous tank was BP, this is Caltex, both 50ppm. --
Post #631323 14th Jun 2017 1:06pm
Naks
gents, which live values should I be monitoring to diagnose if it is the VCV?
fuel rail pressure? --
Post #631493 15th Jun 2017 8:17am
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
My 2.4 has symptoms which according to other threads is VCV, hunting, lacklustre feel, rough cold idle, so I reckon at around £40 a new VCV is worth a try.
However, I've only got an icarsoft i810 obd computer thing and I don't know if that will do the re-learn.
What happens if I don't do the learn, does it eventually learn itself over a number of miles?
Post #631652 15th Jun 2017 5:50pm
Page 2 of 4 <1234>
