Home > Technical > Pilot bearing grease?
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
Does anybody know what the correct grease is for the pilot bearing then? V8 90...WIP
Post #632358 19th Jun 2017 9:52pm
g-mack
i don't even know what the pilot bearing is Shocked My 109 thread
my youtube channel
Post #632370 19th Jun 2017 11:02pm
Paulv8
Also known as a spigot bearing V8 90...WIP
Post #632376 19th Jun 2017 11:31pm
g-mack
ah got ya Thumbs Up sorry never done one so can't help Very Happy My 109 thread
my youtube channel
Post #632378 19th Jun 2017 11:39pm
Paulv8
I had a feeling that would be at least one answer so you still get ten Internet points. V8 90...WIP
Post #632379 19th Jun 2017 11:41pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Soak it in engine oil for 48 hours, and fit to crankshaft Thumbs Up
Post #632393 20th Jun 2017 7:01am
Paulv8
I am not replacing it. I am just changing the clutch. I am reliably informed that after 40k miles and its first clutch change there is no need to change it. However, the LR manual says 'use the correct grease' but fails to tell you what that is. Being as I known that some brass bushes do indeed need soaking in engine oil before fitting, I am at a loss to understand exactly what should be done here.
I am thinking that I will just use some silicon grease and leave it at that - but thought I would check here first. V8 90...WIP
Post #632398 20th Jun 2017 8:02am
Spigot bushes (and indeed similar bushes) are traditionally made from a porous sintered and usually bronze based material which is vacuum impregnated with oil at manufacture. In the old days it was recommended to soak them in SAE30 oil for 24 hours prior to fitment. They are generally considered to be fit-and-forget, except on the TD5 when they squeal like pigs at the slightest opportunity.
When I bought my Disco2 in 2002, one of the service actions was to replace the bush, because there was a bad batch which hadn't been lubricated properly. Fifteen years later and it is starting to squeal a little again now and then.
I imaging that any good-quality, fairly light, lithium based grease will do no harm, but apply very sparingly since you don't want it getting on the clutch.
Post #632400 20th Jun 2017 8:35am
Disco_Mikey
£6 for a new bush from Land Rover v's taking the gearbox out again
I know what I'd be doing Thumbs Up
Post #632403 20th Jun 2017 8:55am
Paulv8
Thank you blackwolf. V8 90...WIP
Post #632409 20th Jun 2017 9:32am
4wheeler
Australia 2013 Defender 110 Puma 2.2 SW Chawton White
Just a word of warning which may be warranted or maybe not from my experience a few years ago.
I know the Ford Transit with the 2.4 engine is not the same vehicle but the components are fairly similar. At 130,000 km (my work van) I felt at times that occasionally when stopping and selecting first gear, the gear would grab a little even though the clutch was depressed. It happened a couple of times. I first thought I wasn't depressing the clutch pedal far enough.
Waiting at the traffic lights early one morning, there was a graunching sound (is that even a word?) and the vehicle lurched forward ever so slightly. I pulled over, switched everything off, checked everything, restarted and off I went. From that point on for a number of weeks there was occasionally a strange noise which I could not identify.
I took the car to the local dealer and explained what had happened. They tested the vehicle and it even made the noise I was concerned about while being driven. The mechanic seemed to think it was no concern but I was not happy and felt it must be clutch or gearbox related. Against the mechanics advice I asked them to drop the gearbox and investigate further.
What was found was that the spigot bearing had collapsed and was binding on the end of the input shaft to the gearbox. The shaft end was cactus and as the van had done 130,000 km it was also decided to replace the clutch and flywheel.
Bottom line was near $6000.00 AUD bill and a vehicle off the road for near 3 weeks as the dealer fiddled around waiting to get the box repaired. All this for a $30.00 bearing. No explanation as to the reason for failure and the dealer said they had not seen this failure before. Obviously a good part of the bill was for a new clutch and flywheel but there would not be much change from $3500.00 if just the gearbox shaft was involved given parts and labour cost to repair.
So while the part might be cheap, make sure you lubricate it correctly or it could be costly.
Post #632422 20th Jun 2017 11:45am
^^ Indeed, a good point. People also nowadays seem to spend far more time with the clutch held out, or riding the clutch, than in the past, and this will of course wear the spigot bearing more (there is only ever movement of the input shaft in the spigot bush when the clutch is out, and the bearing really isn't intended to be very heavy duty).
So if you want a long trouble free life from both your clutch release bearing and your spigot bearing, drive properly and use the clutch properly!
4wheeler wrote:
... there was a graunching sound (is that even a word?) ...
I am please to put your mind at rest, "sound" is definitely a word! Rolling with laughter
Post #632431 20th Jun 2017 12:57pm
Paulv8
You can replace any and all parts. But...and it's a big but, new isnt always good. I've had to replace a thrust bearing that was 2000 miles old before after it broke down, so replacing with new isn't always a good call. I have taken the decision to not replace the spigot bearing because I believe it to be in good condition and have had two independent Land Rover specialists give me the same advice. They didn't tell me what grease to use tho Smile
Thumbs Up V8 90...WIP
Post #632434 20th Jun 2017 1:05pm
MK
A while back I used NGLI-3 shell grease and it has been going fine. Puma 110" SW
Post #632445 20th Jun 2017 1:40pm
Paulv8
Thanks MK V8 90...WIP
Post #632515 20th Jun 2017 9:11pm
