Home > Puma (Tdci) > 2.4 Clutch Issues |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5804 |
Hello Nick,
I had the very same problem, will try and find the thread. After an almighty amount of f*$€ing about, and a lot of blame and counter blame, I bit the bullet, took the Def to a new garage, and had it re-stripped (third time of asking) and fitted with a brand new plate. The new garage's belief (they estimate they have done 1400 clutches and are Ashcroft's recommended fitters), was that at the first attempt the bell-housing had been re-fitted at a slight angle and bent the fingers on the clutch plate. The result (by the sounds of things) was exactly as you describe and we (the original mechanic and I) went through every attempt to make it work (Bleed, change both cylinders, even re-opening and re-fitting the same replacement clutch), but no improvement. Sounds like you may have suffered the same problem. BTW, something seems to linger in the back of my mind that 130s use a HD clutch. Is this what you re-fitted and not a stock 2.4? Someone out there will confirm... Good luck Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
19th Jun 2017 1:41pm |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 |
Grenadier! Thanks for that. I did see the post you made and its also given me a little optimism that I will solve the problem! I am fitting the normal clutch and cover and not aware of the 130 having a HD version. The 130 300tdi does have a HD version. 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
20th Jun 2017 6:50am |
