Home > Maintenance & Modifications > Martin's Ctek adapter for the 12S tow electrics
ericvv
Post #632056 18th Jun 2017 9:56am
flydive
Switzerland 2015 Defender 90 Puma 2.2 Heritage Edition SW Grasmere Green
Quite easy to make one yourself if Martin does not sell it anymore.
Post #632061 18th Jun 2017 11:03am
ericvv
Yes, but the one by Martin is very nicely finished with a built in added fuse. Just a very nice finish for a good price, so would like to buy one of these again. Let's see what Martin says.
Martin, if you would not produce these anymore, but if you still would have one or two lying around somewhere, I'll take it/both of them.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #632066 18th Jun 2017 11:36am
Martin
Site Admin
Hi Eric,
Yes I will be doing these again, I just need some time to build up stock as doing them "to order" isn't time efficient Smile
Martin  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #632208 19th Jun 2017 11:26am
Likeomg
Any idea on eta and a price?
Post #632563 21st Jun 2017 1:37am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I could be interested as I'm currently weighing up the idea of converting to the euro style plug but I could run 12s/n with a adapter 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #632564 21st Jun 2017 5:10am
Naks
hi guys,
stupid questions:
why can't the plug be used with the OEM towing socket? or are the electrics different?
can one build a plug to fir the original towing socket? --
Post #632576 21st Jun 2017 8:02am
ericvv
The standard 7 pin socket (12N) has no permanent live connection to the battery. So of no use. Only the additional 7 pin (12S) caravan socket has such permanent live connection to the battery and thus can be used for a Ctek charger.
Post #632577 21st Jun 2017 8:13am
zsd-puma
Or the 13 pin towing socket.
You could connect the Ctec to the permanent live behind the right hand rear speaker.
Post #632594 21st Jun 2017 9:47am
Martin
Site Admin
Back on the shop: http://www.defender2.net/shop/tow-electric...c-p45.html
Shipping will start in the middle of next week Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #632596 21st Jun 2017 9:56am
ericvv
Not very practical, no?
You would have to remove the interior trim first which not something you want to do all too often, and then still fabricate a connector for the Ctek charger to that purple live wire. And then that only works for the Puma 2.4 upto a certain model year, later model years and all Puma 2.2 do not have that purple wire in that location anymore.
Martin's solution with the Ctek adapter for the 12S and for the 13 pin sockets is just perfect, easy-peasy. Thumbs Up
As Martin said, they are back in the store now. Just ordered one as a spare.
Post #632677 21st Jun 2017 5:24pm
ericvv
Arrived today in the post. Thanks for the note with the explanation of the small design change, Martin. Thumbs Up
And another good thing is that the envelope carried the green sticker from Swiss customs which reads "Abgabefrei". Whistle
Post #636312 7th Jul 2017 10:57pm
zsd-puma
I've just added a cigar lighter socket plugged permanently into that connector behind the speaker. So i could just plug a charger into that. It wouldn't be hard to mount any kind of socket you want on the trim. But anyway it was just an alternative suggestion.
Post #636338 8th Jul 2017 5:39am
Baz8046
United Kingdom 2002 Defender 90 Td5 HT Rutland Red
I use a Ctek adapter on the dash for the Defender as I don't have a 12S socket.
It also gives you an indication of battery charge and you can run a cable out through the bottom corners of the doors.
I do have one of Martin's adapters for the Disco and it's a great bit of kit.
 Defender Td5 Commercial 2002
Range Rover L322 TDV8 Westminster 2012
Discovery 4 SDV6 Landmark 2016
Post #636384 8th Jul 2017 12:21pm
