Home > In Car Electronics > Grommet and connector references |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5111 |
Can't help with the connectors but the cable ties with fir tree look here
https://www.ebay.co.uk/sch/i.html?_odkw=ca...p;_sacat=0 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
16th Jun 2017 3:30pm |
flyingfab Member Since: 14 Jun 2015 Location: Brittany Posts: 60 |
Great I didn't know that this was was called "fir tree" ... Thanks a lot !
Just missing the grommet and connector references now |
16th Jun 2017 10:49pm |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 |
You can get various grommet styles to suit from companies like these guys
http://www.polevolt.co.uk/acatalog/Grommets.html 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
17th Jun 2017 7:35am |
there is enough free play in those grommets to push extra cables throught them along side the existing cables, even if you put the extra cables in additional (smaller) conduit. Land Rover themselves advocate this when fitting the towing electrics for example.
17th Jun 2017 10:45am |
Good to know But I prefer to use an additional hole/grommet. This makes my work easier, since I usually crimp and make the whole wiring on a workbench, including fitting the grommet onto the wiring ... then fit it onto the car. That's why I need to a dedicated grommet
Thanks Jomara ! That will be useful for another work ... but quite different from what I'm currently looking for. I am really looking for the factory style grommet |
17th Jun 2017 12:47pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1418 |
I don't know whether this is any good for you but on my older Defender there is are 2 grommets on the tunnel part of the bulkhead which are easy to get access to via the cab, under the carpets.
It's number 11 on this diagram and the part number is MTC1650, there is one either side. I used one of them to run a cb aerial into the cab Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
17th Jun 2017 2:17pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 502 |
Unfortunately, Polevolt only post to the UK Land Rover don't list the battery cable grommets separately, they come with the battery cables. However, they do list these grommets as spare parts, you'll have to measure the diameter of the hole to determine the correct size - http://new.lrcat.com/#!/1235/2632/2988/227 The style of grommet you need is Callout 2, the part numbers for which, are - 233244 - GROMMET BLACK CABLE 3 X 19MM 233243 - GROMMET BLACK CABLE 3 X 25.5MM 269257 - GROMMET BLACK CABLE 6 X 33.5MM 555711 - GROMMET CABLE 6 X 33.5MM RED 276054 - GROMMET BLACK CABLE 6 X 41.5MM 589452 - GROMMET BLACK CABLE 7 X 53MM 233566 - GROMMET CABLE 12.5 X 48MM RED . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
17th Jun 2017 3:43pm |
Yes I'll take the measurement but I'm pretty sure one of those will fit perfectly !
Many thanks |
17th Jun 2017 10:58pm |
Ouch ! Finally, according to my measurements, none of them will fit perfectly (diam. 4.7mm)
The closest would be the the ref.233566 ... but its 12,5mm hole is too wide, I'm afraid. So, I'm considering drilling a 25mm hole into the rigid capping in order to fit a rubber grommet on it. That might work |
18th Jun 2017 11:00pm |
Hello !
Some unexpected (good) news : I finally realized that the free opening was probably smaller than I initially thought. So, I ordered a grommet ref. 276054 (6 X 41.5MM), just in case I would be lucky. And I was : this grommet fits perfectly well in the opening !! Thanks you all for your good tips Fabien |
25th Jun 2017 10:33pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20446 |
As that grommet fits perfect that's brilliant. (Thank you for letting us know Fabian.)
I assume the hole is 40mm or possibly 41 mm dia? If the grommet is 41.5 dia. I don't suppose anyone knows off the top of their head? If not I can accurately measure anyway, I may need an additional hole or two added for cable routing. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
26th Aug 2018 8:55pm |
It's probably 42mm or thereabouts. The spec. of the grommet will be for the hole it fits in rather than the outer diameter. Darren
26th Aug 2018 9:56pm |
Ah yes, good call I'm thinking of the dimensions the opposite way around aren't I.
I'll give it a measure with the micrometer to be sure. I was considering using ip68 glands but the just don't look right especially from underneath. (Mainly because of their size and protrusion.) No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
26th Aug 2018 10:40pm |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 486 |
Later battery cable grommet through seat box is 12.5X48 mm part number 233566 But £8.50 each minimum quantity 5!
18th Nov 2024 4:46pm |
